matteyp |
Nothing a little JB Weld can't fix... ![]() ![]() Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest ![]() |
Does anyone know if the right and left side outside door handles on the 914s are interchangeable? I someone have 3 door handles and all of them are stamped with an L. I put the left door handle on the right and it seemed to work ok. Wondering why there stamped L and R if there interchangable. Thanks
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
They can be used on both sides. However if you look closely at a R and a L, the shape of the handle is different. The piece that you pull on to open it follows the shape of the door edge.
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
They can be used on both sides. However if you look closely at a R and a L, the shape of the handle is different. The piece that you pull on to open it follows the shape of the door edge. (IMG:style_emoticons/default/agree.gif) I've heard a rumor that if you get a flap from an R door and put it on an L doorhandle and it will work on the L side. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:32 AM |
