scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Gint, Andy whoever did it. Thanks, I gave all an hours advance warning. Can we PLEASE get back to the cars now ?? (IMG:style_emoticons/default/smile.gif)
I will do it again if neccesary (IMG:style_emoticons/default/dry.gif) |
Ian Stott |
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada ![]() |
George can you post a pic of the pedal area where you can see the spring that may be for the brake light switch when you get a chance. I'm doing clean up in that area and want to remove everything and a pic is so helpful when putting it back together.
Ian Stott Moncton Canada |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
yes coming very shortly Ian. Please remember that the brake switch has its own spring in it. It is always in the on position and the pedal washer resting against it keeps it off. THAT way, as soon as you TOUCH the pedal the light comes on.
George can you post a pic of the pedal area where you can see the spring that may be for the brake light switch when you get a chance. I'm doing clean up in that area and want to remove everything and a pic is so helpful when putting it back together. Ian Stott Moncton Canada |
Lo-Fi Version | Time is now: 29th June 2024 - 12:42 AM |
