BIGKAT_83 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,799 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States ![]() ![]() ![]() |
What started as quick and easy conversion for a Grassroots motorsports 2000 challenge car. One thing led to another and before I knew it I had gone over budget.
I started with a V8 car with a bad engine so instead of another SBC or LS1 I bought a wrecked Subaru SVX for the engine. Then found a wrx transaxle with axles clutch and all parts needed. The engine and transaxle mounts were done over a couple of weekends. Then we got real busy at work and was not able to work on it for a couple of months. By this time I had changed my mind about the grassroots challenge car and figured I just fix it up. So a color change paint job was in order. I did this myself in the garage and had to wait until spring to shoot the paint. I've been driving now for a few days tuning the Megasquirt DIYPNP that I built over the winter. I guess its time to go get a tag and start driving. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Bob (IMG:style_emoticons/default/driving-girl.gif) |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
The MR2 shifter works out well because the cable bulkheads point to the rear; the Corolla/Celica stuff points forward though they can be turned around. Another shifter to add to the list is from an 80's-90's Mitsubishi. Whatever shifter you use, it may require translation to get the right direction of movement. I buy my cables from Control Cables, Inc. (Tuthill distributor) in SoCal. They'll make up any cable length, any end, any bulkhead all by phone and a credit card. McMaster-Carr can do it too, but it takes longer and they can't give you any technical advice.
Andys |
barada |
Member ![]() ![]() Group: Members Posts: 257 Joined: 5-October 08 From: Atlanta Member No.: 9,613 Region Association: None ![]() |
The MR2 shifter works out well because the cable bulkheads point to the rear; the Corolla/Celica stuff points forward though they can be turned around. Another shifter to add to the list is from an 80's-90's Mitsubishi. Whatever shifter you use, it may require translation to get the right direction of movement. I buy my cables from Control Cables, Inc. (Tuthill distributor) in SoCal. They'll make up any cable length, any end, any bulkhead all by phone and a credit card. McMaster-Carr can do it too, but it takes longer and they can't give you any technical advice. Andys Bob your car has turned out well. You have me really thinking about swapping engines and building the 914 into something fun. Not sure if you remember or not but you bought some 16x7's from me. Phillip |
Lo-Fi Version | Time is now: 19th April 2025 - 01:16 PM |
