> Need my V8 Guru's, fill and expansion tanks
Howard
post Mar 29 2004, 09:29 PM
Incontin(g)ent Member
Car was in at Otto's last few days. He did all the 'Porsche' stuff and called in Rod Simpson to take a look at conversion. Rod said it was fine, but should have an updated radiator to run cooler. Since the current one does leak a bit, I may go ahead and have him change out.
He also said that cooling setup is wrong, since fill tank and expansion tank should be near the radiator, not the engine. Seems to me that as long as both are high in the system, it doesn't really matter. Once pressurized, even the height shouldn't matter.
Opinions? How is your's set up?
campbellcj
post Mar 29 2004, 10:05 PM
I can't Re Member
Do (most) V8 conversion cars run oil and/or trans coolers?
Howard - I meant to go check out your car while it was at the shop. (My office is 2 miles from there.) Been crazy busy lately, though. (IMG:style_emoticons/default/headbang.gif)
Howard   Need my V8 Guru's   Mar 29 2004, 09:29 PM
boxstr   Howard I have read posts from other V8 owners who ...   Mar 29 2004, 09:42 PM
Brad Roberts   Rod tells everyone this. With the RH setup I run a...   Mar 29 2004, 09:50 PM
campbellcj   Do (most) V8 conversion cars run oil and/or trans ...   Mar 29 2004, 10:05 PM
Howard   As always, invaluable info. Craig, what radiator...   Mar 29 2004, 10:21 PM
Brad Roberts   Howard, The V8 914 crowd will be REAL happy to se...   Mar 29 2004, 10:26 PM
Howard   Brad, he really should have my whale tail. 1200...   Mar 29 2004, 10:33 PM
Brad Roberts   It already has a wing. The roller weighs 1400lbs, ...   Mar 29 2004, 10:36 PM
Andyrew   Under 2k.. 1200hp.. umm 1.6 hp to weight ratio? ...   Mar 29 2004, 10:49 PM
neo914-6   Howard, Brad and Chung installed the RH rad in my ...   Mar 30 2004, 12:23 AM
neo914-6   Someone's front mounted expansion (RH also)...   Mar 30 2004, 12:24 AM
BIGKAT_83     Mar 30 2004, 03:00 AM
BIGKAT_83
  Mar 30 2004, 06:58 PM
datapace   Rich, Some food for thought. I thought that was ...   Mar 30 2004, 07:21 PM
Brad Roberts   I like the rubber. It bounces back when you hit it...   Mar 30 2004, 11:14 PM
rick 918-S   ...   Mar 30 2004, 11:30 PM
Brad Roberts   FYI: The Boxsters and 996's run 2 steel 1 inc...   Mar 30 2004, 11:33 PM
rick 918-S
  Mar 31 2004, 02:11 AM
Brad Roberts   They where the same. The differences where in the ...   Mar 31 2004, 02:18 AM
BIGKAT_83   I bought a used housing off of Ebay and installed ...   Mar 31 2004, 05:27 AM
Lawrence   Brad wrote:
...   Mar 31 2004, 06:49 AM
Brad Roberts   Bob, quick note here for you: I have been closel...   Mar 31 2004, 10:05 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 01:29 AM
