BIGKAT_83 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,799 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States ![]() ![]() ![]() |
What started as quick and easy conversion for a Grassroots motorsports 2000 challenge car. One thing led to another and before I knew it I had gone over budget.
I started with a V8 car with a bad engine so instead of another SBC or LS1 I bought a wrecked Subaru SVX for the engine. Then found a wrx transaxle with axles clutch and all parts needed. The engine and transaxle mounts were done over a couple of weekends. Then we got real busy at work and was not able to work on it for a couple of months. By this time I had changed my mind about the grassroots challenge car and figured I just fix it up. So a color change paint job was in order. I did this myself in the garage and had to wait until spring to shoot the paint. I've been driving now for a few days tuning the Megasquirt DIYPNP that I built over the winter. I guess its time to go get a tag and start driving. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Bob (IMG:style_emoticons/default/driving-girl.gif) |
BIGKAT_83 |
The evaporator I'm using is a slimline underdash unit with heat and A/C . It also has a defrost where it directs air to a set of vents. I have these going to the stock 914 defrost vents.
Bob Attached image(s) ![]() |
bfrymire |
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California ![]() |
The evaporator I'm using is a slimline underdash unit with heat and A/C . It also has a defrost where it directs air to a set of vents. I have these going to the stock 914 defrost vents. Bob Do you have any pictures with it installed in the car? THis is similar to what I want to use. -- brett |
Lo-Fi Version | Time is now: 19th April 2025 - 01:18 PM |
