toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
what is the pin number on the connector on the relay board for the fuel pump?
I am going to use it for the AAR. It's been so long since I've messed around with the relay board, I've forgotten. Thanks |
toon1 |
I'm running a Megasquirt FI. It has the capability to run a on and off AAR selonoid but for some reason it is not working.
I am going to use the stock AAR until I get my MS fixed. I am running the FP through the R B on for the MS so the stock connector is avail.. I figured I'd tap into that for now. |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
I'm running a Megasquirt FI. It has the capability to run a on and off AAR selonoid but for some reason it is not working. I am going to use the stock AAR until I get my MS fixed. I am running the FP through the R B on for the MS so the stock connector is avail.. I figured I'd tap into that for now. Messing around with megasquirt is the reason i know the stuff i do about the fuel pump circuit. Basically, the stock AAR wiring will not work with a standard MS install as the AAR is powered by the fuel pump relay which is no longer being activated by the stock ECU. Attempting to wire the AAR directly to the stock fuel pump source is not going to solve your problem because they are both fed by the same relay. I will have to go find my notes to give you exact details but, there is a wire that runs from the stock ECU to the fuel pump relay, this pin needs to be grounded to activate the stock fuel pump relay. Normally this is done by the stock ECU but with MS the stock ECU is gone so neither the fuel pump nor the AAR will be powered . Megasquirt can be pretty easily adapted to trigger the stock fuel pump relay which I think is the best way of doing it however you could also just wire the AAR into the MS fuel pump circuit or just put a manual switch on the stock relay. Ideally if you are using the stock AAR you want it powered at the same time as the fuel pump, i.e. only when the engine is running. Simply powering the AAR with key on 12v could heat it prematurely and defeat the purpose of having it all together. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:38 PM |
