reharvey |
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States ![]() |
I'm getting ready to build a 2.0 engine for my latest 914 project. I've put together several of these motors in the past but have always used the Euro type Mahle 94mm pistons. How big of a piston can I use and still retain the FI. I can make minor modification to the FI if need be. I've done this in the past. Has anyone out there try this?
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Hey Mr. Self Righteous, your way is not the only way. Lots of other people have had success and quite a few of us nail it the first time. Recognize that. Accept it. Jake you are incrediblly talented and we value you as a knowledgeable resource, but stop crapping on the rest of us that have been successful.
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Hey Mr. Self Righteous, your way is not the only way. Lots of other people have had success and quite a few of us nail it the first time. Recognize that. Accept it. Jake you are incrediblly talented and we value you as a knowledgeable resource, but stop crapping on the rest of us that have been successful. You have perceived what I have said incorrectly, but that may be my fault because it was written incredibly clearly to get a point across. The original poster asked if the stock system could be used on a larger engine, something of 2.4 liters of displacement. The direct answer to that is yes. The best way to explain what the person doing the modification may experience would be: "Results may vary" One of the only times that I have failed when I put my efforts into getting a result was working with the constraints of stock FI. I see lots of people make lots of mistakes, these mistakes vary from internal design that makes an engine impossible to tune, to improper placement of components that cause their car to burn to the ground. We are generally a last resource for people that can't figure it out and that gets really old, especially when people call up down and out having lost thousands of dollars and have nothing to show for it except an engine that won't run. If I have to hurt some feelings to help people see that they should put more consideration into their project before opening their wallet, I am willing to do that. This post has been edited by Jake Raby: Jan 15 2011, 08:33 AM |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Hey Mr. Self Righteous, your way is not the only way. Lots of other people have had success and quite a few of us nail it the first time. Recognize that. Accept it. Jake you are incrediblly talented and we value you as a knowledgeable resource, but stop crapping on the rest of us that have been successful. You have perceived what I have said incorrectly, but that may be my fault because it was written incredibly clearly to get a point across. The original poster asked if the stock system could be used on a larger engine, something of 2.4 liters of displacement. The direct answer to that is yes. The best way to explain what the person doing the modification may experience would be: "Results may vary" One of the only times that I have failed when I put my efforts into getting a result was working with the constraints of stock FI. I see lots of people make lots of mistakes, these mistakes vary from internal design that makes an engine impossible to tune, to improper placement of components that cause their car to burn to the ground. We are generally a last resource for people that can't figure it out and that gets really old, especially when people call up down and out having lost thousands of dollars and have nothing to show for it except an engine that won't run. If I have to hurt some feelings to help people see that they should put more consideration into their project before opening their wallet, I am willing to do that. I used to have a Murphy's Law calendar in my office. My favorite one was this, "It never fails, that when you make something absolutely, 100%, crystal clear; you are going to confuse someone! |
Lo-Fi Version | Time is now: 25th June 2024 - 11:55 PM |
