nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
brad's thread brought this up. i'm curious what others say about it.
my 2 cents: i've used it with good success on things like lawn mowers and such. it's a hack-fix in most cases, no doubt. however, you can drill it, machine it, file it, etc., so it's pretty damn strong. and permanent. certainly in carb mods, i wouldn't think twice about using it. i've heard different things regarding temperature. they used to say 600 degrees, the manufacturerer now says 500. apparently, it won't actually melt to liquid at that temp, it will just stop holding. so i wouldn't use it as part of an exhaust. a smog tube (that i've blocked off) on my 75 2.0 came out while driving the other day. not good. threads of the stud are still good, so the head is probably cracked and shit. however, i can just set the stud through the tin into the head and the car runs great, no problem. engine still makes all kinds of power and sounds smooth, and i don't currently have the time and space to pull it... so i just put a spot of jb weld on the stud in the upper threads, and a spot of it where the stud meets the engine tin. i'm crossing my fingers... it claims to work well w/ aluminum, but i'm a little concerned about differing expansion rates... and heads can run pretty hot (hopefully not 500 degrees), although my car seems to cool well. this is hackmye, no doubt -- i'll let you know if it holds... anyone else use the stuff? n |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Used it all the time on the race track to repair FUBARS on all parts the engine & drivetrain - bulletproof - actually a product that lives up to and beyond it's name
(IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 04:27 AM |
