ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,545 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
I'm assembling the pieces that I'll need to rebuild my 1973 2.0L engine that will retain the stock FI. I'm wondering about cam choices and why I would want to choose a particular one. The only change I've made from stock at this point is that I've got Mahle Euro pistons & cylinders, but they are stock size so there is no increase in displacement.
I hear a lot about the Web Cam 73 and here's the info I've been able to find on how it compares to stock: Type/Lift/Duration/Duration @ .050 Stock/.392/?/210 73/.426/262/224 Am I correct that Duration is how many degrees both intake and exhaust are open? Or is that called Overlap? If it is called Overlap, does anyone know the specs on the two cams? What is the difference between Duration and Duration @ .050? Lift is pretty obvious - the 73 is going to open farther. I assume this means it can deliver more fuel mixture in the same amount of open time compared to the stock lift. My car is a daily driver that will probably never see anything more exciting than a PCA autocross. So how do I choose a cam and why do I want one or the other? |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Overlap is easily calculated with any "cam card" just look at the opening and closing events and do the math. The difference is "overlap"
Lo-Fi Version | Time is now: 24th June 2024 - 07:49 AM |
