Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Ok sittin ghere at lunch running it through the old brian bucket.
Anybody have something to add ?? Flying Saturday Driving it from Everret back to Mississippi on the 6th. CHANGE OIL, ENGINE CHANGE OIL, TRANSAXLE ADJUST VALVES CHANGE FUEL FILTER DRAIN GAS CHECK BRAKE PADS CHECK WHEEL BEARINGS CHECK CLUTCH FREE PLAY CHECK CV JOINTS CLEAN THROTTLE BODY AIR FILTER CHECK / REPLACE CHECK FUEL HOSES CHECK VACCUUM LINES CHECK IGNITION POINTS CHECK CAP & ROTOR CHECK FUEL INJECTION POINTS CHECK PLUGS AND GAP CHECK ALT BELT INSTALL HEAD TEMP GAUGE INSTALL OIL PRESSURE GAUGE WIPER BLADES CHECK ALL LIGHTS CHECK ELECTRICAL GROUNDS FIX DEFROST CHECK THROTTLE CABLE CHECK CLUTCH CABLE CHECK WINDSHIED WASHER SYSTEM CHECK SHIFT LINKAGE CHANGE BRAKE FLUID TAPE UP ENGINE TIN TAPE UP FAN OUTLETS CHANGE HEAD LITES H-4 euro 55/65 Stay tuned to this thread I will be posting lots of parts cheap. Just as soon As I get pics or better description. CHEAP especially if you pick up. |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Come through on HWY 5 and we can organize a dinner for you with the NorCal gang.
B |
Lo-Fi Version | Time is now: 25th June 2024 - 12:03 AM |
