> Pictures of Our 2 914's, Wife & I Doing 2 Restorations 1970 & 1976 914
badboybear
post Jan 29 2011, 11:59 AM
[size=3]Here are a few pics that I said I would share for thoughts & input on doing restoration to our 2 Porsche's 1970 Yello & 1976 Brown. Thanks for the support & help. We will start by sending to our mechanic the first week of March 2011...wifes first, hers is the 76'. Will update with pics and things done/completed along the way. Thanks,
Mike & Theresa (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/piratenanner.gif)
badboybear
post Jan 29 2011, 12:35 PM
Attached ImageAttached Image
QUOTE(badboybear @ Jan 29 2011, 09:59 AM) *
Tom_T
post Jan 30 2011, 07:08 PM
TMI....
QUOTE(badboybear @ Jan 29 2011, 10:35 AM) *
Look for original paint on both 914s under the carpets, up under the dash, inner thresholds/longitudinals, behind the gas tank & interior & exterior firewall pads, the drip pan on the engine lid, uo in the slots where the targa top rear latches are on the roll-bar, etc. for hints of the original colors where a repaint might not have reached (unless they did a full strip down & repaint), to verify the original color - esp. on the 76. These areas are also likely to be largely unfaded (door jambs are too easy to repaint, so not as reliable).
I agree that it doesn't look like a Sepia Brown, and it looks like a metallic paint.
Also, there is an outside chance that a Certificate of Authenticity (COA) from Porsche Cars North America (PCNA) may actually list the original "98" color chosen by the OO/1st buyer, depending on how complete the Kardex factory records were (and whether the PCNA-COA staff reads the codes right (IMG:style_emoticons/default/dry.gif) ). This will also tell you if the engine and transaxle case nos. still match the original (photo them first to verify & send).
Porches Club of America (PCA) also gets $20 or so off the $100+ COA cost, as well as several 20% off orders from Porsche a year & a monthly national & local magazine - so well worth $42/yr. for you & wife IMHO - aside from their various events. I wasn't a member until I started a resto of my 73 914-2.0 in 09, but it's been well worth it to me, and many on here have been long time members - even back when the PCA's 356/911/912/etc. snobs turned their noses up at 914s. Nowadays most think they're cool. (IMG:style_emoticons/default/biggrin.gif)
Here's other sources for the early 1970's colors for 914s (along with other references such on here at the 914 info above - so cruise around those websites). They also might help you on your work on the 914s - so go to their respective home pages & peruse their other sections (esp. Bowlsby's, rennlist & p914), as well as for finding the actual color once you find an unfaded & unchanged paint area as noted above.
http://www.bowlsby.net/914/Classic/PaintFabrics.htm
http://www.p914.com/p914_paint_70.htm
http://www.p914.com/p914_paint_76.htm
http://members.rennlist.com/914_collectibl...aintFabrics.htm
http://members.rennlist.com/chuxter/914Colors.htm
http://members.rennlist.com/chuxter/914ColorMatrix.gif
http://www.914world.com/bbs2/index.php?act=colors
http://homepage.mac.com/markd/914/colors.html
http://www.914world.com/bbs2/index.php?sho...=39488&st=0
http://www.glasurit.com/en_UK/COLOR/Classi...olors/index.xml
http://autocolorlibrary.com/acl_files/volkswagen.html
http://autocolorlibrary.com/acl_files/Porsche.html
badboybear
post Jan 31 2011, 06:16 PM
QUOTE(Tom_T @ Jan 30 2011, 05:08 PM) *
Tom, Ferg sent us alot of "Brown" 911 carcolors. We beleive it is a "Copper Metallic Brown" we looked everywhere and it is the same, like you indicated above...the color code tag has not been removed nor has the sticker that indicates the month/year build. If it is how can we confirm and add to new color for a 914?
Mike
post Jan 31 2011, 06:32 PM
Resident German
QUOTE(badboybear @ Jan 31 2011, 04:16 PM) *
Mike,
post a picture of the door jamb tag with the paint code and a picture of the original paint where it is the most vivid. Any otherwise protected area, good lighting and a little bit of cleaning should result in a good image of the paint.
A picture of the date code sticker in the door jamb would also help.
That should be enough to confirm that we have indeed found a new 98 code!
badboybear   Pictures of Our 2 914's   Jan 29 2011, 11:59 AM
badboybear   How do you add pics? [size=3]Here are a few pic...   Jan 29 2011, 12:00 PM
type47   bottom of the screen, File Attachments. Browse to ...   Jan 29 2011, 12:03 PM
badboybear   I did that and then when I previewed no pics? Sta...   Jan 29 2011, 12:08 PM
type47   :popcorn: :wttc:   Jan 29 2011, 12:04 PM
badboybear   :popcorn: :wttc: Says not enough file space?   Jan 29 2011, 12:14 PM
kg6dxn   Make sure your pics are smaller than 500kb. After ...   Jan 29 2011, 12:14 PM
badboybear   Make sure your pics are smaller than 500kb. After...   Jan 29 2011, 12:15 PM
ppetion   Make sure your pics are smaller than 500kb. After...   Jan 29 2011, 12:18 PM
badboybear   Make sure your pics are smaller than 500kb. Afte...   Jan 29 2011, 12:23 PM
badboybear   [quote name='ppetion' post='1424015' date='Jan 29...   Jan 29 2011, 12:39 PM
Tom_T   [quote name='ppetion' post='1424015' date='Jan 29...   Jan 29 2011, 06:47 PM
badboybear   [quote name='ppetion' post='1424015' date='Jan 2...   Jan 30 2011, 08:31 AM
Dr Evil   I use MS paint to shrink them. It is included with...   Jan 29 2011, 12:28 PM
badboybear   I use MS paint to shrink them. It is included wit...   Jan 29 2011, 12:36 PM
badboybear   [quote name='badboybear' post='1424005' date='Jan ...   Jan 29 2011, 12:35 PM
Tom_T   [quote name='badboybear' post='1424005' date='Jan...   Jan 30 2011, 07:08 PM
badboybear   [quote name='badboybear' post='1424005' date='Ja...   Jan 31 2011, 06:16 PM
badboybear   [quote name='Tom_T' post='1424511' date='Jan 30 2...   Jan 31 2011, 06:20 PM
Tom_T   Tom, Ferg sent us alot of "Brown" 911 ...   Feb 1 2011, 06:12 AM
badboybear   [quote name='badboybear' post='1425043' date='Jan...   Feb 1 2011, 07:40 AM
SirAndy   Tom, Ferg sent us alot of "Brown" 911 ca...   Jan 31 2011, 06:32 PM
ppetion   Nice!..   Jan 29 2011, 12:50 PM
badboybear   Nice!.. Thanks...should we keep or redo in ...   Jan 29 2011, 12:53 PM
Tom_T   Nice!.. Thanks...should we keep or redo in...   Jan 29 2011, 07:02 PM
Dr Evil   Always go with what YOU want ;)   Jan 29 2011, 12:59 PM
abayer1969   :wttc: Just remember its your car paint it whatev...   Jan 29 2011, 01:04 PM
Ferg   I'll be the weenie, and say stay original what...   Jan 29 2011, 01:30 PM
SirAndy   What's the paint code on the wife's 76, fr...   Jan 29 2011, 02:48 PM
badboybear   What's the paint code on the wife's 76, f...   Jan 31 2011, 06:13 PM
badboybear   I'll be the weenie, and say stay original wha...   Jan 29 2011, 11:45 PM
MDG   Her's is a "98"...sephia Brown if I...   Jan 30 2011, 06:40 AM
badboybear   Her's is a "98"...sephia Brown if ...   Jan 30 2011, 08:22 AM
Eric_Shea   :agree: Unless you strip and dip you can "ne...   Jan 29 2011, 02:09 PM
MDG   Great cars! Good luck on the projects - I can ...   Jan 29 2011, 02:36 PM
championgt1   That's cool. Leave it brown. :beer2:   Jan 30 2011, 12:02 AM
markb   That's cool. Leave it brown. :beer2: :agree...   Jan 30 2011, 12:28 AM
badboybear   That's cool. Leave it brown. :beer2: :agre...   Jan 30 2011, 08:26 AM
jt914-6   The side shift tranny came in '73........   Feb 1 2011, 08:11 AM
badboybear   The side shift tranny came in '73........   Feb 1 2011, 08:17 AM
Tom_T   The side shift tranny came in '73........   Feb 2 2011, 05:22 PM
badboybear   The side shift tranny came in '73........   Feb 2 2011, 05:28 PM
jim_hoyland   Two great projects ! Hope to you can bring bot...   Jan 30 2011, 08:24 AM
badboybear   Two great projects ! Hope to you can bring bo...   Jan 30 2011, 08:29 AM
badboybear   Two great projects ! Hope to you can bring bo...   Jan 31 2011, 06:54 PM
Ferg   BROWN RULES :worship: I'd would need to see ...   Jan 30 2011, 01:05 PM
badboybear   BROWN RULES :worship: I'd would need to see...   Jan 30 2011, 01:16 PM
Ferg   [quote name='Ferg' post='1424349' date='Jan 30 20...   Jan 30 2011, 01:28 PM
badboybear   [quote name='Ferg' post='1424349' date='Jan 30 2...   Jan 30 2011, 01:39 PM
SirAndy   The color code of 98 is that just for a "gene...   Jan 30 2011, 01:47 PM
badboybear   BROWN RULES :worship: I'd would need to see...   Jan 31 2011, 06:30 PM
JRust   I know those 2 cars. Looked at them a few times in...   Jan 30 2011, 03:50 PM
badboybear   I know those 2 cars. Looked at them a few times i...   Jan 31 2011, 07:02 PM
Ferg   Copper Brown Metallic like the pic above was a 76 ...   Jan 30 2011, 03:53 PM
JRust   Good to talk to you Mike. Nice to have some more t...   Jan 31 2011, 09:49 PM
badboybear   Good to talk to you Mike. Nice to have some more ...   Feb 1 2011, 07:37 AM
Ferg   Sounds like Copper Brown Metallic is going to be c...   Feb 1 2011, 09:01 AM
badboybear   [quote name='Ferg' post='1425322' date='Feb 1 2011...   Feb 1 2011, 01:53 PM
Ferg   [quote name='Ferg' post='1425322' date='Feb 1 201...   Feb 1 2011, 01:55 PM
Tom_T   [quote name='Ferg' post='1425322' date='Feb 1 201...   Feb 2 2011, 07:56 PM
Tom_T   Sounds like Copper Brown Metallic is going to be ...   Feb 2 2011, 07:49 PM
kg6dxn   Restoration Design has all the body parts you need   Feb 2 2011, 05:34 PM
badboybear   Restoration Design has all the body parts you nee...   Feb 2 2011, 05:40 PM
Tom_T   Restoration Design has all the body parts you nee...   Feb 2 2011, 07:44 PM
PanelBilly   You can send you cars up my way and I'll give ...   Feb 2 2011, 07:58 PM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st February 2025 - 12:07 PM
