Mini Starter Problem, Won't disengage |
jgara962 |
Feb 7 2011, 10:18 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
I installed one of thoese E-bay mini hi torq starters about a year and a half ago. It has just 500 miles on it and has worked great until last summer. I hadn't started the car in a while, and when I would start the car, everything was fine until it actually fired and the starter wouldn't disengage.
McMark suggested changing the starter button I had installed a few years earlier thinking that was faulty, but the problem continued. I did notice that the more frequently I started the car (every couple of weeks instead of months) that it would disengage quicker until if finally started working normally. Now that it has been sitting most of the winter, the couple of times I've tried to start it, the problem continues. Has anyone else experience this? Is it a lack of use issue? I e-mailed the company I got it from to see if they had any suggestions, but haven't heard back. |
Tom |
Feb 8 2011, 08:15 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Also the mechanism that "kicks" the gear out. Any misalignment can cause binding. Might need some higher temp lube on the solenoid and shaft. Maybe disassemble the solenoid and clean everything up and lightly lube. During disassembly, you may see what the binding is caused by.
Tom |
Lo-Fi Version | Time is now: 6th January 2025 - 05:04 PM |
