> Mini Starter Problem, Won't disengage
jgara962
post Feb 7 2011, 10:18 PM
Yo, this is how I roll
I installed one of thoese E-bay mini hi torq starters about a year and a half ago. It has just 500 miles on it and has worked great until last summer. I hadn't started the car in a while, and when I would start the car, everything was fine until it actually fired and the starter wouldn't disengage.
McMark suggested changing the starter button I had installed a few years earlier thinking that was faulty, but the problem continued. I did notice that the more frequently I started the car (every couple of weeks instead of months) that it would disengage quicker until if finally started working normally. Now that it has been sitting most of the winter, the couple of times I've tried to start it, the problem continues. Has anyone else experience this? Is it a lack of use issue? I e-mailed the company I got it from to see if they had any suggestions, but haven't heard back.
IronHillRestorations
post Feb 8 2011, 12:59 PM
I. I. R. C.
They won't call you back. Pull the starter and test it on a bench. You may be able to lubricate the mechanism that extends the gear, which is probably what is sticking. You also need to closely examine the ring gear on the flywheel, as the small starters have been known to eat them up!
- Lo-Fi Version Time is now: 6th January 2025 - 05:10 PM
