carnitasboy |
Newbie ![]() Group: Members Posts: 2 Joined: 8-March 10 From: San Diego Member No.: 11,444 Region Association: Southwest Region ![]() |
Is there a difference in a 2.0L out of a bus as opposed to a 2.0L out of a 914? I was under the assumption that a bus engine had different heads. I don't know where I heard that. Maybe I just made that up.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Bus crankshafts have the pilot bearing (same part as the one used in a 914) installed in the crank because the mainshaft is longer. Bus cranks for use with an auto trans don't have the bearing. 914s have the bearing in the flywheel. The bearing in the bus crank doesn't interfere with anything in the 914 application, so it can be left in place.
The Cap'n |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Bus crankshafts have the pilot bearing (same part as the one used in a 914) installed in the crank because the mainshaft is longer. Bus cranks for use with an auto trans don't have the bearing. 914s have the bearing in the flywheel. The bearing in the bus crank doesn't interfere with anything in the 914 application, so it can be left in place. The Cap'n True, but when I have had the cranks worked on they pull the bearing so "IF" you are going to use a crank without the bearing put a bearing in or that stop. Otherwise the bearing on your 914 flywheel will move around into the crank and the pilot shaft will flop around. Nah, the rods and crank are the same, even have a 039 part number as Porsche figured out how to built the 2.0L as VW thought you could only go to 1800 with a 66mm stroke. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:21 AM |
