Saturday, 5 April 2025
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
Andyrew
post Jan 19 2011, 01:01 PM
Spooling.... Please wait
Welcome to my Audi Turbo 914 build thread! This first post has been highly edited for your(and my) ease of navigation.
(IMG:http://www.914world.com/bbs2/uploads/post-172-1428991066.jpg)
The car 1973 Porsche 914 1.7 w/ appearance group package
(IMG:http://www.914world.com/bbs2/uploads/post-172-1429499049.jpg)
The Story:
I purchased this car when I was 14years old and had bought 2 other 914s with it for a measly $1100, The other 2 914’s were basket cases and one had been in a roll over. The previous owner put the 2.0 from the roll over car in this car. I parted out the other two cars and DID A V8 CONVERSION on mine after I couldn’t figure out how to adjust the valves (It seemed easier..). I do a 5 lug conversion as well as put some fiberglass flares on the car and many other things before I decide to paint the car. That is the start of this thread.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1295463716.1.jpg)
Next I decide that I don’t like how the v8 drives and how I could never keep it cool so I decide to embark on a journey with an engine I was already more familiar with. The Audi 1.8T.
To start at the 1.8T engine conversion click below.
http://www.914world.com/bbs2/index.php?sho...4780&st=309
Details on the car:
Engine: Audi AEB 1.8t Engine, Fully rebuilt, balanced rotating assembly and blueprinted, balanced and clearanced Intermediate shaft.
Crankshaft: Stock/polished
Rods: Scat Forged I beam rods
Pistons: Stock
Cams: Stock
Valves: Stock intake, Stainless nitrite coated Supertech exhaust AEVN-1103
Valve springs: Supertech high rpm valves SPRK-AUDI18
Piston rings: Goetze 08-502900-00 (Factory stock)
Head gasket: Elring Stock head gasket
Rod bearings: 034 Dry film coated bearings 034-202-1008
Crank bearings: 034 Dry film coated bearings 034-202-1000
Intake Manifold: Stock
Throttle Body: Stock AWM
Exhaust Manifold: APR Iconel Stage 3 manifold
Exhaust: 3" turbo back stainless steel w/ 2 stainless resonators
Intercooler: 700hp air to water core.
Turbo: Comp Turbo triple ball bearing CTB5356
Injectors: Bosch 550CC injectors ported and flow matched to 1300CC
Fuel Pump: Bosch 044 inside 034 Surge tank
Fuel rail: Stock fed with AN10 line
Water pump: Davies Craig EWP150 w/ LCD controller
MAF: PMAS HPX MAF in 3" housing
Boost controller: Cortex EBC
Transmission: Audi A4 1.8 5 speed code EHV FWD unit
100mm stub axles from boxster transmission
eBay sprung type LSD
Wiring: Strip all Porsche wiring, Replace with Audi wiring 100%
Engine Management: Modified OEM Audi Ecu
Power brakes: Not yet
ABS integration: Not yet
Traction control integration: Not yet
Launch control: Not yet
Cruise control: Yes
Climate control/AC: Yes
OBD2 full control: Yes
Check engine light: No smile.gif
Front trunk and rear trunk: YES!
8psi: 240whp (Canyon and autox setting)
14psi: 280whp (Street)
17PSI: 300whp (Track and Street driving) (Estimated power goal)
30psi(E85): 400whp (Full tilt mode)
Suspension:
Raised 911 spindals up front with Koni yellows
Mueller Roller Needle Bearings front and rear in leu of all bushings
Turbo tie rods
22mm Torsion bars
Nascar front sway bar
Koni yellows rear
911 rear hubs with 100mm studs
Ground control coil over kit in rear
225lb springs
Brakes:
911 A calipers front
Stock 914 rear calipers
Vented rotors front and rear
Porterfield semi race pads
19mm M/C
Proportioning valve replaced with T
Wheels:
Boxter rear 17 x 8.5 twists up front with 245 40 17
911 turbo 18 x 10 turbo twists in back with 285 35 18
Body:
Rich Bontempi HPH Flares Front and Rear, Molded
916 front and rear bumpers (front bumper to be reworked completely)
6" ducktail spoiler with supports
Engman long stiffening kit
Seam welded rear
Camp 914 hood shocks rear
Camp 914 Euro front turn signals
Bike rack (IMG:style_emoticons/default/biggrin.gif)
Interior(In Progress):
Fully custom interior (Still in design phase)
Harness Bar
5 point Cam lock harnesses
Pepboys Corbeau style seats
Now that the intro is done, here is my checklist of things that I want to get done with it.
Register *5-15-11*
Fix ignition **5-30-11**
Tune (again) ecu ** Converted back to Carbs after ECU died 5-30-11**
Clean goo in trunk (pic)
Install Dr window crank *5-30-11*
Change oil ****Finished 1-29-11****
Change water pump *Received Remanufactured pump from Slits 1-26-11****Finished Install w/ hangups 1-29-11****
Flush coolant
Finish targa bar S *Started progress on the bar*
Dr front 1/4 *Sand day 1 1-29-11* *Bondo Day 2-1-11**Primer Day 2-19-11*
Dr door *Sand day 1 1-29-11**Bondo Day 2-1-11*[/url]*Primer Day 2-19-11*
Rocker pannels *5-7-11*
Dr rear 1/4 *Sand day 1 1-29-11**Bondo Day 2-1-11*[/url]*Primer Day 2-19-11*
Trunk *Removed spoiler, Plugged old spoiler holes, Long board sanded trunk*
Rear bumper *Page 8*
Pass rear 1/4 *4-17-11*
Pass door *4-17-11*
Pass front 1/4 *4-17-11*
Front bumper *5-5-11*
Hood *Primer 5-2-11* *Paint 5-15-11*
Top *5-4-11[url=http://www.914world.com/bbs2/index.php?showtopic=114780&st=120#]
Primer sealer *5-15-11*
Paint *5-15-11*
Radiator cutouts in wheel well (And replace hood with stock) ***Completed 1-26-11***
Fix headlights *6-8-11*
Fix horn
Finish seat install ****Progress 1-19-11**** ***Finished 1-26-11***
Finish carpet *6-8-11*
Finish front sway bar
Fix Dr Door handle
This post has been edited by Andyrew: Jan 15 2022, 09:16 PM
Andyrew
post Feb 11 2011, 03:42 PM
Well the biggest problem is this car can actually USE the spoiler.. Without a spoiler the rear end gets REALLY unstable at speeds much over 100mph. I've been at 145 with just the small ducktail spoiler and that was just a bit scary.. This spoiler is a larger spoiler and should have better downforce at lower speeds. I was also considering the "vortex generators" on one of my spare tops, which should help get wind to the spoiler.
I think i'll just get another trunk as a spare and have it flush... For now i'll paint this hood with the spoiler.
Andyrew   Andyrews Progress Thread   Jan 19 2011, 01:01 PM
Andyrew   After http://www.914world.com/bbs2/uploads/post-17...   Jan 19 2011, 01:04 PM
kg6dxn   AWESOME! :Qarl: I want you to drive and enjo...   Jan 19 2011, 01:26 PM
Andyrew   At this point its either... Im even entertaining a...   Jan 19 2011, 01:37 PM
underthetire   Going to be one hell of a ride :D I'm thinkin...   Jan 19 2011, 01:41 PM
pt_700   will be following this with great interest as i pl...   Jan 19 2011, 01:49 PM
Andyrew   F.I setup: Its actually a pretty great unit, HOWEV...   Jan 19 2011, 02:18 PM
shoguneagle   WHAT???? YOU HAVE NOT BEEN WORKING OR DRIVING ...   Jan 19 2011, 05:59 PM
SGB   Sounds like a rocket. You should look at Tangerin...   Jan 19 2011, 07:05 PM
arkitect   Andrew, Go with a Audi engine like you want, don...   Jan 19 2011, 09:16 PM
Andyrew   Got some progress done on the Pass side seat. The...   Jan 20 2011, 01:24 AM
ernestj911@gmail.com   This is a great 914 one the inspirations for me to...   Jan 21 2011, 12:54 PM
Gint   Is it done yet? :evilgrin:   Jan 21 2011, 08:20 PM
Andyrew   :D Nope, Very little going to be done today... I ...   Jan 22 2011, 02:08 PM
Andyrew   No progress tonight on the 914, however I did spen...   Jan 25 2011, 01:19 AM
Andyrew   Finished the seat install!! I actually did...   Jan 26 2011, 11:16 PM
Lennies914   Looking good Andrew. Is that an orange band badge ...   Jan 26 2011, 11:22 PM
Andyrew   Looking good Andrew. Is that an orange band badge...   Jan 27 2011, 12:26 AM
kg6dxn   :Qarl: :Qarl: :Qarl: :Qarl: :Qarl: :Qarl: ...   Jan 26 2011, 11:39 PM
Justinp71   Lookin Good!   Jan 27 2011, 12:38 PM
Andyrew   Thanks! Progress from lunch today. All radi...   Jan 27 2011, 02:21 PM
Andyrew   Progress from today! Finished removing the w...   Jan 28 2011, 05:48 PM
matthepcat   Right on. Just get her driving again, and you will...   Jan 28 2011, 07:55 PM
kg6dxn   It looks like nothings wrong with that pump. Most ...   Jan 28 2011, 08:25 PM
Andyrew   Replace it anyways. Its the pump that came with my...   Jan 28 2011, 11:16 PM
Andyrew   Progress so far today. Been working since 9am, unf...   Jan 29 2011, 07:56 PM
kg6dxn   I like Mopars. Here's a pic of my old car... ...   Jan 29 2011, 08:02 PM
Andyrew   Thats a bad ass mopar mike!   Jan 29 2011, 08:21 PM
Andyrew   Bit the bullet. Started ~ 8 finished ~ 11. htt...   Jan 30 2011, 02:08 AM
Andyrew   Havent got a working compressor at the house yet s...   Feb 2 2011, 12:20 AM
computers4kids   Dang Andrew...you really are serious about getting...   Feb 2 2011, 09:10 AM
Spoke   Lookin' good. Do you have a long board sander ...   Feb 2 2011, 09:27 AM
Andyrew   Mark, Yup, To be perfectly honest, I forgot to re...   Feb 2 2011, 10:30 AM
orange914   andrew, you planning on spraying it? sounds like ...   Feb 2 2011, 06:41 PM
Andyrew   andrew, you planning on spraying it? sounds like...   Feb 3 2011, 10:43 AM
kg6dxn   Andrew, What type of flares are those? How wide w...   Feb 2 2011, 07:24 PM
McMark   Aren't those just 911SC flares? :rotfl: [Mik...   Feb 2 2011, 08:58 PM
kg6dxn   Aren't those just 911SC flares? :rotfl: [Mi...   Feb 2 2011, 09:09 PM
Andyrew   Got some more filler layed down http://www.914wor...   Feb 4 2011, 11:36 PM
computers4kids   Got some more filler layed down http://www.914wo...   Feb 5 2011, 10:09 AM
Andyrew   They were Yummy! Today I didnt get near as ...   Feb 5 2011, 08:17 PM
Andyrew   Got a little progress today before the game starte...   Feb 6 2011, 08:39 PM
orange914   Got a little progress http://www.914world.com/bbs...   Feb 10 2011, 12:48 PM
Andyrew   Finished up sanding the LR fender tonight. I was a...   Feb 7 2011, 12:32 AM
Andyrew   Made some progress yesteday and today. Not enough ...   Feb 10 2011, 01:27 AM
pt_700   i prefer my 914's rather unadorned (in respons...   Feb 11 2011, 12:24 PM
Andyrew   Haha! Nah, that wouldnt be over the top now wo...   Feb 10 2011, 01:16 PM
Beach914   Yup, You need to do a dually rear set up to get ti...   Feb 10 2011, 01:38 PM
Hontec   Man, that's a lot of work going into filling/s...   Feb 11 2011, 06:43 AM
Andyrew   Yup, Bodywork is always extremely laborous... Espe...   Feb 11 2011, 10:19 AM
Andyrew   Well the biggest problem is this car can actually ...   Feb 11 2011, 03:42 PM
Lennies914   It's good to see the progress you're makin...   Feb 11 2011, 09:11 PM
computers4kids   Andrew, If you ever want to tow your car down her...   Feb 12 2011, 09:47 AM
J P Stein   Not many lunatics have the urge to modify the targ...   Feb 12 2011, 11:09 AM
J P Stein   Spoiler?.....yeah, that's the ticket. If a li...   Feb 12 2011, 11:14 AM
Andyrew   I'll update this thread tomorrow. Not much to ...   Feb 13 2011, 11:45 AM
Andyrew   Vday weekend I didnt do much like I said. http:/...   Feb 16 2011, 02:25 AM
kg6dxn   :trophy:   Feb 16 2011, 09:44 AM
Andyrew   Lets start with Friday. I didnt get near as much...   Feb 20 2011, 03:18 AM
Andyrew   PRIMER DAY!!! I should have done some...   Feb 20 2011, 03:42 AM
computers4kids   Andrew, the car is looking great! I think tha...   Feb 20 2011, 08:31 AM
Andyrew   It has been amazing having my dad be with me throu...   Feb 20 2011, 02:11 PM
dan10101   It has been amazing having my dad be with me thro...   Feb 20 2011, 03:18 PM
Andyrew   One of my all time favorite pictures of my car :) ...   Feb 20 2011, 03:50 PM
JRust   Looking great Andrew! Love custom flares. You ...   Feb 20 2011, 04:48 PM
kg6dxn   Love the progress! BTW, paint those wheel spa...   Feb 20 2011, 06:47 PM
arkitect   Andrew, Great job...making a ton of progress. Are ...   Feb 20 2011, 11:54 PM
Andyrew   Mike, Ya I probably should paint those. Dave, ...   Feb 21 2011, 12:29 AM
Gint   That's pretty cool. Good prgress Andrew, kee...   Feb 21 2011, 09:10 AM
Andyrew   Met a local forum member and really great guy toda...   Feb 23 2011, 02:03 AM
Andyrew   Went to my parents durring lunch and picked up a c...   Feb 23 2011, 02:20 PM
Andyrew   http://www.914world.com/bbs2/uploads_offsite/i1210...   Feb 28 2011, 01:33 AM
Andyrew   So I dont have many pictures of the sanding to 220...   Mar 7 2011, 02:01 PM
Lennies914   :beer2: Looking great Andrew. WCR this year?   Mar 7 2011, 08:31 PM
Andyrew   Lennie, Not in the cards this year $$...   Mar 7 2011, 09:31 PM
Andyrew   http://www.914world.com/bbs2/uploads_offsite/i1210...   Mar 13 2011, 11:11 PM
Andyrew   No pics today.. I only got a couple hours to work ...   Mar 16 2011, 12:52 AM
orange914   (Im pretty sure he wants to paint it black too.. ...   Mar 16 2011, 05:33 PM
Andyrew   Got some mixed progress done tonight. Finished g...   Mar 24 2011, 12:37 AM
Andyrew   My friends geo with what took so much welding. Ful...   Mar 24 2011, 12:40 AM
Andyrew   This weekend wasnt completely a wash.. I got to wo...   Mar 28 2011, 10:48 AM
kg6dxn   Great progress! keep going :headbanger: I ne...   Mar 28 2011, 10:53 AM
Andyrew   You could build one of these... http://www.carport...   Mar 28 2011, 10:59 AM
kg6dxn   You could build one of these... Im contemplating...   Mar 28 2011, 11:01 AM
Andyrew   Progress from yesterday http://www.914world.com/bb...   Mar 30 2011, 09:39 AM
Andyrew   Worked Saturday night and 1/2 the day on Sunday. ...   Apr 4 2011, 11:33 AM
Andyrew   http://www.914world.com/bbs2/uploads_offsite/i1210...   Apr 6 2011, 09:21 AM
kg6dxn   Looking good! :beer1:   Apr 6 2011, 01:54 PM
Andyrew   Progress from today. Laid a bunch of filler/glaze ...   Apr 11 2011, 12:26 AM
kg6dxn   Nice progress. I'm impressed! :trophy:   Apr 11 2011, 08:52 AM
Andyrew   Today was spent chasing down light bulbs... Arg......   Apr 13 2011, 12:12 AM
computers4kids   :) Tomorrow Im going to try to convince the GF to...   Apr 13 2011, 08:11 AM
mepstein   Today was spent chasing down light bulbs... Arg.....   Apr 13 2011, 08:39 AM
Andyrew   :P I had her weld about 4 years ago.. Turned out...   Apr 13 2011, 09:35 AM
McMark   Kickin' ass! :headbanger:   Apr 13 2011, 10:10 AM
Spoke   Car is lookin' good. Love the garage paint boo...   Apr 15 2011, 02:56 PM
sawtooth   Nice progress :trophy: I hope be painting about a ...   Apr 15 2011, 03:45 PM
Andyrew   Thanks guys! I was able to get some done this ...   Apr 15 2011, 08:48 PM
AZ914   Lookin good man...   Apr 15 2011, 08:52 PM
Andyrew   Sprayed about 4 layers of primer on... Stupid be m...   Apr 16 2011, 12:52 AM
9 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 5th April 2025 - 04:58 AM
