| thenewwazoo |
Feb 15 2011, 01:50 PM
Member ![]() ![]() Group: Members Posts: 56 Joined: 3-October 09 From: RWC Member No.: 10,883 Region Association: Northern California |
(bloody hell those smilies to the left are distracting)
Here's some quick info regarding suby transmissions and clutch assemblies. There are two main types of suby clutches - "push" and "pull". Relative to the stock configuration, a "push" clutch has the slave cylinder mounted on the engine side of the clutch fork and actuates toward the driveshaft end. The "pull" clutch has the slave cylinder mounted near the center of the transmission and actuates toward the engine. The type of clutch actuation is dictated by the combination of the flywheel, clutch, pressure plate, throwout bearing, clutch actuation fork, and the slave cylinder. All of these items must be matched in terms of fork actuation direction. A transmission can be converted from pull to push by flipping the pull slave cylinder and using a kit - some bellhousings may have bolt holes for using either type, but I don't believe this to be the case. Note that cable-actuated clutches actuate in the "push" direction. So here's a quick cheat sheet for transmissions and clutch actuation direction. From the factory on cars sold in the USA, 1.8, 2.2L engines came with cable-actuated clutches (Impreza -'01, Legacy -99?) 2.5L non-turbo engines came with push-style hydraulic clutches (Legacy 96+, Impreza 98+, Forester all years) 2.0L turbo engines came with pull-style clutches (02-05) 2.5L turbo engines in the WRX came with push-style clutches (06-09) 2.5L turbo engines in the STi came with pull-style clutches (04+) You cannot mix and match flywheels with clutches across these (e.g. no WRX clutch on an N/A flywheel, no push WRX clutch with a pull WRX flywheel, etc). You also cannot use an STi fw/clutch/pp in a non-STi bellhousing without some grinding, and you still must use a pull-style clutch fork actuation. Why does this matter? Two reason: power and packaging. Due to the proliferation of WRXes and the relative scarcity of high-power N/A cars, there are basically no cheap or livable options for N/A clutches that will handle real power. If you're not going to be making more than realistic power for a 2.5L N/A (say, about 200 lb-ft), you can use any clutch combination you want. If you are going make more power, you can either shell out BIG bucks ($800+) for an N/A clutch/fw/pp kit, or you can find a way to make a WRX or STi clutch work. So why not just grab a WRX clutch/fw/pp and stick it on any old gearbox? The gearbox might not have the bosses required to mount a pull-style slave cylinder. Why not just use a WRX transmission? The pull-style clutch actuation mechanism is physically large, and it's on the top of the transmission, right where the 914 has lots of metal. The push clutch cylinder is smaller, lives closer to the engine where there's space, and can be more easily made to fit inside the 914 transmission tunnel without cutting. The solution, then, is simple - you need a WRX clutch with a push-style clutch actuator. Luckily, that's what Subaru moved to with the WRX in '06+. You can use a stock N/A slave cylinder and clutch fork with an 06+ WRX flywheel, clutch disk, pressure plate, and throwout bearing! This matters because WRX boxes are expensive (easily twice the cost of an N/A box of the same year), rarer since the N/A transmissions have been around since the early '90s, and basically identical in terms of capability when used in a 914. 06+ WRX flywheels aren't terribly cheap yet, but prices are coming down all the time. '06+ transmissions, however, are still really expensive. What this means is that, when you're doing shopping, you must consider the transmission, that transmission's clutch actuation direction, and then what flywheel/clutch/pp combos match that direction. You can work backwards or forwards, but they must necessarily follow in that direction unless you want a headache. (IMG:style_emoticons/default/smile.gif) |
| DukeTrout |
Feb 16 2011, 02:47 PM
Newbie ![]() Group: Members Posts: 10 Joined: 18-January 11 From: Oregon Member No.: 12,609 Region Association: Pacific Northwest |
Here's some quick info regarding suby transmissions and clutch assemblies. Another thing to take into consideration in higher-hp builds is the "front" differential. In almost all of the transmissions thenewwazoo listed, the "front" differential is open, which would lead to 1-wheel drive in some situations. The STi 6-speed has a helical front differential that's tuned more for pulling the car through corners. It might be an interesting effect when applied in a RWD configuration. There are differentials on the market that can be added to the WRX and Legacy GT 5-speeds and the 2007-2009 Legacy GT spce.B 6-speeds, but that would involve cracking the transmission. Still, might be worth it compared to the $ of a high-demand STi transmission. |
Britain Smith Subaru Engine Conversion Wiki Sep 9 2010, 10:57 AM
Britain Smith [b]Cooling System
[u][b] - Radiators
I have se... Sep 9 2010, 10:57 AM
Britain Smith [b]Engine Mounting
[u][b] - Stock Subaru Mount P... Sep 9 2010, 10:58 AM
DBCooper
DBCooper - Modified Renegade Engine Cradle.
http... Jan 10 2013, 04:03 PM
DBCooper doppelpost
. Jan 10 2013, 04:05 PM
Britain Smith Transmission Options
There are several different ... Sep 9 2010, 10:58 AM
Britain Smith Intake System
Couple of places to get tubing:
[u... Sep 9 2010, 10:58 AM
Britain Smith [b]Exhaust System
[u][b] - Headers
[img]http://... Sep 9 2010, 10:58 AM
charliew
[b]Exhaust System
[u][b] - Headers
[img]http:/... Sep 13 2010, 09:45 PM
Britain Smith Electronics
- Stock ECU
- Aftermarket ECU
- ... Sep 9 2010, 10:59 AM
Britain Smith [b]Oil System
[u][b]- Different Sump Pans
Outfro... Sep 9 2010, 10:59 AM
charliew
[b]Oil System
Outfr... Sep 10 2010, 12:28 AM
Britain Smith Fuel System
- Stock Tank
- Aftermarket Tank
- Fuel... Sep 9 2010, 10:59 AM
Britain Smith Other/Misc.
- Parts that you will need but are not... Sep 9 2010, 11:33 AM
Britain Smith I will start going back and editing my posts with ... Sep 9 2010, 11:39 AM
Andyrew Coming along nicely! Think you can include lin... Sep 9 2010, 06:33 PM
bigvag I would like someone to come out with a how to mak... Sep 9 2010, 06:36 PM
charliew
I would like someone to come out with a how to ma... Sep 10 2010, 12:33 AM
Britain Smith CharlieW,
That is an interesting pan, I will add ... Sep 10 2010, 09:58 AM
Britain Smith Lots of updates today. Enjoy.
-Britain Sep 10 2010, 10:55 AM
Britain Smith Anyone have some new stuff to add.
-Britain Sep 12 2010, 07:46 PM
Andyrew Very interesting motor mount you added. Uses the s... Sep 12 2010, 07:57 PM
charliew
Very interesting motor mount you added. Uses the ... Sep 13 2010, 10:02 PM
blitZ Pretty good summary. I've been looking for a ... Sep 13 2010, 07:31 AM
dlo914 Here's what our smallcar engine mount looks li... Sep 14 2010, 11:28 AM
Britain Smith Thanks for the pic.
The one difference I see betw... Sep 14 2010, 11:34 AM
Sleepin Not a whole lot to contribute here, but I wanted t... Sep 14 2010, 03:54 PM
JRust I'd like a link or someone who knows the subar... Oct 23 2010, 09:26 PM
bfrymire
I'd like a link or someone who knows the suba... Oct 24 2010, 12:55 AM
DukeTrout This is a late reply, but I thought I'd chime ... Feb 14 2011, 01:06 PM
abayer1969 Britain thanks for the work. Nice to see all of th... Oct 24 2010, 05:20 PM
d914 intersting site for older JDM motors
http://www.c... Oct 24 2010, 05:35 PM
d914 and my build thread..
http://www.914world.com/bbs... Oct 24 2010, 05:41 PM
NC_Colfax What is everyone using for electronics??
How do t... Oct 27 2010, 06:31 PM
Britain Smith Hey Duke...here is my Subaru conversion thread. I... Feb 14 2011, 01:21 PM
DukeTrout Thanks for the link, Britain. I've been lookin... Feb 15 2011, 01:54 PM
sawtooth Something that may be useful for guys considering ... Feb 15 2011, 03:04 PM
BIGKAT_83
Something that may be useful for guys considering... Feb 15 2011, 05:56 PM
strawman
I did what they suggested in my suby trans, ... Feb 16 2011, 05:54 PM
sawtooth
I did what they suggested in my suby trans,... Feb 16 2011, 10:25 PM
strawman
I'm just making a judgment call here, I don... Feb 17 2011, 01:38 PM
sawtooth
Thanks for this info. I'll have to crawl unde... Feb 17 2011, 01:52 PM
Britain Smith
Thanks for the link, Britain. I've been looki... Feb 15 2011, 05:08 PM
DukeTrout I live over on the East side suburbs, but I work i... Feb 16 2011, 02:27 PM
utah914 Has anyone done heat with a suby swap? Feb 14 2011, 01:45 PM
malaga_red75
I have been going thru several of the threads reg... Feb 14 2011, 05:23 PM
d914 The down side of the six speeds besides cost ,,, t... Feb 16 2011, 05:44 PM
904svo some wiring tricks.
http://www.914world.com/bbs2/i... Jan 10 2013, 04:51 PM
scotty b I recall someone somewhere ( ClubNARP most likely ... Jan 15 2013, 09:22 AM
DBCooper It's pretty cool how a forum that no-one visit... Jul 15 2013, 03:53 PM
BIGKAT_83 Here you go.works like a champ. The fuel pressure ... Jan 15 2013, 11:30 AM
scotty b awesome. Thanks Bob. :beer2: I've been lookin... Jan 15 2013, 12:59 PM
Chris H. Yeah and that plastic screw-top is a PITA to get o... Jan 15 2013, 02:46 PM
BIGKAT_83 No I just ran it the way I got it out of the Impre... Jan 15 2013, 02:57 PM
Chris H. Ahhhhhh.... I misunderstood you. That's norma... Jan 15 2013, 03:01 PM
jimkelly notes to self ...
how to convert trans from awd t... Jul 23 2013, 10:20 AM
CptTripps Can we update some of the data in this thread? The... Oct 17 2013, 09:38 AM
1stworks great info!!!!!!
Thank yo... Mar 7 2014, 11:31 AM
76-914 Hmmmmmm, mine is an EZ30D, not the EG33. Mar 7 2014, 03:40 PM
mgp4591
But did... Mar 7 2014, 03:57 PM
76-914 Initially I thought I would go the EG route but th... Mar 7 2014, 04:20 PM
mgp4591
Initially I thought I would go the EG route but t... Mar 7 2014, 04:27 PM
Initially I thought I would go the EG route but ... Feb 4 2018, 02:47 PM
r_towle
[quote name='mgp4591' post='2007585' date='Mar 7 ... Feb 4 2018, 05:08 PM
[quote name='mgp4591' post='2007585' date='Mar 7... Feb 4 2018, 05:22 PM
r_towle
[quote name='r_towle' post='2575107' date='Feb 4 ... Feb 4 2018, 06:18 PM
[quote name='r_towle' post='2575107' date='Feb 4... Feb 4 2018, 06:56 PM
badmiata I saw this on 818 forums. Its very expensive ... Mar 9 2014, 08:22 PM
charliew well I'm still lurking and watching all the ne... Jun 22 2016, 11:45 AM
76-914 Where the Hell have you been, Charlie? Good to see... Jun 22 2016, 12:20 PM
charliew I forget to ask my friends who go to the same chur... Jun 25 2016, 12:21 PM
Optimusglen Any info on putting the radiator in the engine com... Feb 3 2018, 02:14 AM
charliew
Any info on putting the radiator in the engine co... Feb 4 2018, 02:02 PM
76-914 Go to the Restoration & Build Threads Forums s... Feb 3 2018, 09:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th September 2026 - 10:06 PM |
