914-6 oil tank question - too many orifices? |
moparrob |
Feb 16 2011, 09:30 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
For the longest time I was having difficulty trying to picture where the oil lines go to and from on a 914-6 conversion - but I think I have most of the issues figured out.
A lot of the problem has to do with the tank I bought. It has 'extra' holes and fittings that most other tanks I have seen did not have. Here is a pic: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1297913412.1.jpg) I finally figured out that fitting 'C' is the AN -12 return line which is usually a hard pipe from the engine which attaches to a flex line to this port. Similarly, I figured that fitting 'D' is the supply line that goes to the oil cooler, which in my case is AN -16 on both ends. The confusion arises out of fittings 'A' and 'B'. Most tanks I see do not have these fittings. Also, my car was only pre-drilled (by the PO) for fittings C,D, the filler, the vent and the filter only. I don't have extra holes for these fittings. So, do I need these fittings A and B? What do they do? If I don't need them, how do I get rid of them? Do I have to braze the holes shut? Or is it easier to just drill the two requisite holes in the engine compartment and use plugs on those fittings? Last question, does anyone know the size and thread of those fittings? Thanks in advance for your help. Rob |
laflaur |
Feb 17 2011, 12:46 PM
Member Group: Members Posts: 162 Joined: 8-June 06 From: Granite Bay Member No.: 6,186 Region Association: Northern California |
Hey are those pipe thread fittings?
Lo-Fi Version | Time is now: 5th February 2025 - 03:44 PM |
