914-6 oil tank question - too many orifices? |
moparrob |
Feb 16 2011, 09:30 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
For the longest time I was having difficulty trying to picture where the oil lines go to and from on a 914-6 conversion - but I think I have most of the issues figured out.
A lot of the problem has to do with the tank I bought. It has 'extra' holes and fittings that most other tanks I have seen did not have. Here is a pic: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1297913412.1.jpg) I finally figured out that fitting 'C' is the AN -12 return line which is usually a hard pipe from the engine which attaches to a flex line to this port. Similarly, I figured that fitting 'D' is the supply line that goes to the oil cooler, which in my case is AN -16 on both ends. The confusion arises out of fittings 'A' and 'B'. Most tanks I see do not have these fittings. Also, my car was only pre-drilled (by the PO) for fittings C,D, the filler, the vent and the filter only. I don't have extra holes for these fittings. So, do I need these fittings A and B? What do they do? If I don't need them, how do I get rid of them? Do I have to braze the holes shut? Or is it easier to just drill the two requisite holes in the engine compartment and use plugs on those fittings? Last question, does anyone know the size and thread of those fittings? Thanks in advance for your help. Rob |
Eric_Shea |
Feb 17 2011, 06:42 PM
PMB Performance Group: Admin Posts: 19,295 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE You can make a cardboard template and register off the other holes to know where to drill if it comes to that. This is painful to watch... (IMG:style_emoticons/default/sad.gif) |
SLITS |
Feb 17 2011, 06:50 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
QUOTE You can make a cardboard template and register off the other holes to know where to drill if it comes to that. This is painful to watch... (IMG:style_emoticons/default/sad.gif) Close your eyes and the pain will go away! (IMG:style_emoticons/default/slap.gif) |
hwgunner |
Feb 17 2011, 08:29 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
QUOTE You can make a cardboard template and register off the other holes to know where to drill if it comes to that. This is painful to watch... (IMG:style_emoticons/default/sad.gif) Close your eyes and the pain will go away! (IMG:style_emoticons/default/slap.gif) Well said! (IMG:style_emoticons/default/sheeplove.gif) |
Lo-Fi Version | Time is now: 5th February 2025 - 03:39 PM |
