recko911 |
Member ![]() ![]() Group: Members Posts: 93 Joined: 6-February 06 From: Los Angeles, CA Member No.: 5,535 ![]() |
Im having some difficulties with adjusting the shifting. All bushings are new, and motor mounts. Where do you set transmission at the side shift. Can someone describe a good process. Thanks
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
If your transmission is good, and you've replaced ALL of the bushings, you just may need to adjust the shifter in the center console. Remove the plate, and I think it takes a 10mm socket?? Isn't everything a 10 or 13? (IMG:style_emoticons/default/biggrin.gif) Loosen it up then shift to a gear and when you find a gear, tighten it back up.
recko911 |
If your transmission is good, and you've replaced ALL of the bushings, you just may need to adjust the shifter in the center console. Remove the plate, and I think it takes a 10mm socket?? Isn't everything a 10 or 13? (IMG:style_emoticons/default/biggrin.gif) Loosen it up then shift to a gear and when you find a gear, tighten it back up. I'm having trouble adjusting at the center console. How to find proper location while 13mm screw is loose. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:01 AM |
