Houston, we have a problem, Gas in the oil--Lots of it |
anderssj |
Feb 18 2011, 07:04 PM
Dog is my copilot... Group: Members Posts: 1,689 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/sad.gif) Got the 914 out tonight for the first time since DEC. It started fine, but after a few minutes idling in the driveway I noticed white smoke from the exhaust; checked the gauges--no oil light, but cold oil pressure was less than normal at idle (1-2 bar instead of 4-5 bar). I shut it off and rechecked the oil; it was WAY high, thin, and smelled strongly of gas.
The car has Dells, DRLA 40s. I figure I have a problem with one/both floats, or the needle seats aren't shutting off the fuel flow. I'll check further tomorrow, but thought that I should check with the good folks here and see if you had any ideas on other possibilities (like fuel pressure too high). Fortunately, no big noises. I'll be changing the oil a couple of times ASAP. Anything else I should do (besides looking for Art Thraen's phone number just in case)? Thanks in advance! Steve A- |
Jesse |
Feb 19 2011, 08:43 AM
Jesse Group: Members Posts: 149 Joined: 15-February 10 From: Mobile, AL, USA Member No.: 11,363 Region Association: South East States |
It's a good practice to always check the oil before starting any old engine, (car, boat, or yard equipment) . when i found the gas in the oil i dropped the oil out and left the drain out while pouring fresh oil in to flush the gas out, let it sit overnight with the plug out, the next day put the plug back in and filled with oil, rolled the engine over 2 times then drained her again. let that drain relly good then refill as if a normal oil change, (dont forget to change the filter). I ran her for about 2hrs around town here, no smoke or prefomance problems. 2 weeks later we went to MUSR the only problem i had up there was rich mixture (we are at sea level here and 1300ft at MUSR) she has run like a dream lately been driving her to work 2x per week 85mi round trip all winter with no problems.
GOOD LUCK (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 01:17 PM |
