tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
I have put some yellow adjustable konis in my car and I cut one of the three bump stops off (the soft one on the top,stock parts, not the ones that came with the konis. yet). I've got just shy of two inches of suspension travel, I would to get as much travel as possible w/o bottoming the shocks or raising the car. I have not bottomed onto the stops yet, but I've not driven it too much since the swap.
Am I safe to cut one more of the bump stops off and only have one stop section ? Should I use the stock stops or koni provided stops? thanks -Rob |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
current stance looks good Rob..
and your A arm looks to be pretty level. I think I would leave it with one section off the snubber for safety...better to bump the snubber than to bottom the shock. I believe the Koni snubber is a bit stiffer rubber, I would problably use those. (IMG:style_emoticons/default/biggrin.gif) On my orange car I had the snubber down to just one section, but that car was considerably lower than your car (IMG:style_emoticons/default/smile.gif) Car is looking good. Attached thumbnail(s) ![]() Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 07:22 AM |
