2.0l Valve Questions |
tornik550 |
Feb 20 2011, 03:27 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am in the process of rebuilding my engine. I am using semi-stock 2.0l heads. I am using stock valves however two of the valves were damaged (1 intake, 1 exhaust). The remaining valves are in excellent condition.
-Would it be best to replace the broken valves with a used intake and exhaust valve or replace all of the valves with an aftermarket type? -What aftermarket stock sized valves are out there? Are they an upgrade or downgrade? -Do I need to have the seats re-cut when I replace the valves (the heads were recently reworked with new seats, guides,etc)? |
Jake Raby |
Feb 20 2011, 07:42 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The one thing that should always be replaced at rebuild time is valves. I'd rather reuse engine bearings as valves!
Lo-Fi Version | Time is now: 27th December 2024 - 09:46 PM |
