Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
There has been lots of interest in the corvair power plant over the years as a possible source of cheap HP for many vehicles. There are used in experimental aviation, dune buggies, buses (such as mine), and in place of many other air cooled VW power plants. They are fairly cheap to buy and build, very easy to build and maintain, and plentiful with readily available parts from several suppliers.
The main divide in the corvair engine line took place in 1965 when the displacement of the engine was moved to 2.7L and was offered in a NA 110HP, NA140HP, turbo 150HP and turbo 180HP. The only differences in the long block between these engines are the nitrided crank found in all but the 110HP, and the heads: 110 had one single barrel on each head, the 140 had 2 with one acting as primary and one as secondary. The turbos had a single barrel blow through setup. The heads are the major limiting factor in the design. They are not built in an intuitive way and rob much hp. The 140 head had bigger valves, but like its 2.0L TIV analog, would drop valve seats due to the limited amount of material between the seats in the head, and the inability of larger seats to shed heat as well as smaller seats. This can, and has been overcome by those who have been rebuilding these heads fro decades by making sure the crush tolerance on the seats are correct, and staking the seats in place. Currently, you can get a set of rebuilt, 140hp larger valved heads, with new hardware and no core for about $1200 from Corvair Ranch in Gettysburg, PA. I bought a set that was rebuilt and had the plenums taken off for tri porting for $1500 shipped off of ebay from Starr Cooke in El Cajon, CA, another well known Corvair entity. Modified with plenum removed for individual runners: ![]() The above uses an adapter that allows the placement of Weber triples. My set came with this adapter. Here is a head with a stock plenum, modified with bungs for FI. This is a 140 head as it has two carb bases on it: ![]() Standard engine: ![]() One of the cool things that many ACVW folks like is that the corvair engine has stock hydraulic lifters on it that use standard lifter, push rod, and rocker parts from Chevy. Easy and cheap to obtain. Another great feature that I like over ACVW is the box design on the case. The top and bottom come off and allow for any maintenance. Swapping rods, bearings, what ever, is easy. |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
We got a new 63 Greenbriar Van - Blue with White stripes & the vinyl houndstooth looking upholstery - which we drove to CA on old 66 (only small bits of I-40 were started then). I think it only had the base 95 hp motor & auto trans (it was ostensibly Mom's DD), but it fried the valves in TX 1/2 way there & we were stuck while the local dealer fixed it (Amarillo IIRC - I was only 10 then, so fuzzy on the details at 58.5! (IMG:style_emoticons/default/blink.gif) ).
Great car, we had 6 small kids (2 - 10 yrs), 2 parents & all slept in the car on the way & every summer trip up to 67 - back from San Diego to Pittsburgh - no AC either! (IMG:style_emoticons/default/blink.gif) As kids grew, Dad added an Army Surplus stretcher across the 2 back bench seats that folded up against the wall for driving, & open for sleeping. When we grew to 4 teens, Dad moved up to a bigger rig. Then Dad got a 67 Chevy 3/4 tom pick-up with 327 ci 2 bbl auto trans & towing pkg. with a cab over camper - ahhhh - the luxury, still no AC though! |
jk76.914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States ![]() |
We got a new 63 Greenbriar Van - Blue with White stripes & the vinyl houndstooth looking upholstery - which we drove to CA on old 66 (only small bits of I-40 were started then). I think it only had the base 95 hp motor & auto trans (it was ostensibly Mom's DD), but it fried the valves in TX 1/2 way there & we were stuck while the local dealer fixed it (Amarillo IIRC - I was only 10 then, so fuzzy on the details at 58.5! (IMG:style_emoticons/default/blink.gif) ). Great car, we had 6 small kids (2 - 10 yrs), 2 parents & all slept in the car on the way & every summer trip up to 67 - back from San Diego to Pittsburgh - no AC either! (IMG:style_emoticons/default/blink.gif) As kids grew, Dad added an Army Surplus stretcher across the 2 back bench seats that folded up against the wall for driving, & open for sleeping. When we grew to 4 teens, Dad moved up to a bigger rig. Then Dad got a 67 Chevy 3/4 tom pick-up with 327 ci 2 bbl auto trans & towing pkg. with a cab over camper - ahhhh - the luxury, still no AC though! Those are great memories. Which jogged mine for some more trivia- Corvair trucks had valve rotators to make them last longer (sounds like it didn't help on yours!) and they also had a transmission oil cooler on the powerglide... |
Dr Evil |
We got a new 63 Greenbriar Van - Blue with White stripes & the vinyl houndstooth looking upholstery - which we drove to CA on old 66 (only small bits of I-40 were started then). I think it only had the base 95 hp motor & auto trans (it was ostensibly Mom's DD), but it fried the valves in TX 1/2 way there & we were stuck while the local dealer fixed it (Amarillo IIRC - I was only 10 then, so fuzzy on the details at 58.5! (IMG:style_emoticons/default/blink.gif) ). Great car, we had 6 small kids (2 - 10 yrs), 2 parents & all slept in the car on the way & every summer trip up to 67 - back from San Diego to Pittsburgh - no AC either! (IMG:style_emoticons/default/blink.gif) As kids grew, Dad added an Army Surplus stretcher across the 2 back bench seats that folded up against the wall for driving, & open for sleeping. When we grew to 4 teens, Dad moved up to a bigger rig. Then Dad got a 67 Chevy 3/4 tom pick-up with 327 ci 2 bbl auto trans & towing pkg. with a cab over camper - ahhhh - the luxury, still no AC though! Those are great memories. Which jogged mine for some more trivia- Corvair trucks had valve rotators to make them last longer (sounds like it didn't help on yours!) and they also had a transmission oil cooler on the powerglide... Valve rotators??? (IMG:style_emoticons/default/confused24.gif) I have not seen these, any pics? I installed the tranz cooler on my PG. It was probably over kill, but I figure I like to floor it over mountain passes, in a bread box, in summer so it couldnt hurt. It was hard to find info on the cooler, it is not common and no pics could be found. I had to consult a guru about how to install and such and still no one could tell me which port is in and which is out. |
jk76.914 |
We got a new 63 Greenbriar Van - Blue with White stripes & the vinyl houndstooth looking upholstery - which we drove to CA on old 66 (only small bits of I-40 were started then). I think it only had the base 95 hp motor & auto trans (it was ostensibly Mom's DD), but it fried the valves in TX 1/2 way there & we were stuck while the local dealer fixed it (Amarillo IIRC - I was only 10 then, so fuzzy on the details at 58.5! (IMG:style_emoticons/default/blink.gif) ). Great car, we had 6 small kids (2 - 10 yrs), 2 parents & all slept in the car on the way & every summer trip up to 67 - back from San Diego to Pittsburgh - no AC either! (IMG:style_emoticons/default/blink.gif) As kids grew, Dad added an Army Surplus stretcher across the 2 back bench seats that folded up against the wall for driving, & open for sleeping. When we grew to 4 teens, Dad moved up to a bigger rig. Then Dad got a 67 Chevy 3/4 tom pick-up with 327 ci 2 bbl auto trans & towing pkg. with a cab over camper - ahhhh - the luxury, still no AC though! Those are great memories. Which jogged mine for some more trivia- Corvair trucks had valve rotators to make them last longer (sounds like it didn't help on yours!) and they also had a transmission oil cooler on the powerglide... Valve rotators??? (IMG:style_emoticons/default/confused24.gif) I have not seen these, any pics? I installed the tranz cooler on my PG. It was probably over kill, but I figure I like to floor it over mountain passes, in a bread box, in summer so it couldnt hurt. It was hard to find info on the cooler, it is not common and no pics could be found. I had to consult a guru about how to install and such and still no one could tell me which port is in and which is out. Valve rotators- can't find a picture, but my 1971 Corvair Parts Master lists them. Part number is 3851837. Looking through the mating parts, the heads are same as in the car, as are valve springs, keepers, and shims. The valves themselves are unique to F.C. (Forward Control- the trucks), and have the note: "Must be used with rotator 3817362." That's a different number than the one listed on the next page! Anyway, the rotator replaces the cap, and is usually thicker so usually the spring is shorter or there is a deeper relief machined in the head or something, but apparently not on the Corvair. Why the valve is different? Don't know. Also, I found nice pics of the powerglide oil cooler ports in the '61 shop manual. I'll scan them tomorrow. Getting too late tonight.... |
Lo-Fi Version | Time is now: 25th June 2024 - 04:51 PM |
