Oil in & on the heat exchanger, to remove and clean or will it burn off |
ELLIOTT |
Feb 21 2011, 09:14 PM
Member Group: Members Posts: 103 Joined: 7-March 10 From: St.Hedwig Tx. Member No.: 11,438 Region Association: None |
Is thier any danger of the oil in and on a heat exchanger catching fire (a little freaky seeing smoke rising out of the engine bay)? I am getting ready to change the push rod tube seals hence the oil and HE's.
thanks Elliott |
Dave_Darling |
Feb 21 2011, 10:31 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
A little oil turns into a lot of smoke. I'd suggest cleaning off as much as you can with brake cleaner. The rest will burn off, but the amount of smoke may surprise you.
--DD |
Lo-Fi Version | Time is now: 28th December 2024 - 03:04 AM |
