Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
There has been lots of interest in the corvair power plant over the years as a possible source of cheap HP for many vehicles. There are used in experimental aviation, dune buggies, buses (such as mine), and in place of many other air cooled VW power plants. They are fairly cheap to buy and build, very easy to build and maintain, and plentiful with readily available parts from several suppliers.
The main divide in the corvair engine line took place in 1965 when the displacement of the engine was moved to 2.7L and was offered in a NA 110HP, NA140HP, turbo 150HP and turbo 180HP. The only differences in the long block between these engines are the nitrided crank found in all but the 110HP, and the heads: 110 had one single barrel on each head, the 140 had 2 with one acting as primary and one as secondary. The turbos had a single barrel blow through setup. The heads are the major limiting factor in the design. They are not built in an intuitive way and rob much hp. The 140 head had bigger valves, but like its 2.0L TIV analog, would drop valve seats due to the limited amount of material between the seats in the head, and the inability of larger seats to shed heat as well as smaller seats. This can, and has been overcome by those who have been rebuilding these heads fro decades by making sure the crush tolerance on the seats are correct, and staking the seats in place. Currently, you can get a set of rebuilt, 140hp larger valved heads, with new hardware and no core for about $1200 from Corvair Ranch in Gettysburg, PA. I bought a set that was rebuilt and had the plenums taken off for tri porting for $1500 shipped off of ebay from Starr Cooke in El Cajon, CA, another well known Corvair entity. Modified with plenum removed for individual runners: ![]() The above uses an adapter that allows the placement of Weber triples. My set came with this adapter. Here is a head with a stock plenum, modified with bungs for FI. This is a 140 head as it has two carb bases on it: ![]() Standard engine: ![]() One of the cool things that many ACVW folks like is that the corvair engine has stock hydraulic lifters on it that use standard lifter, push rod, and rocker parts from Chevy. Easy and cheap to obtain. Another great feature that I like over ACVW is the box design on the case. The top and bottom come off and allow for any maintenance. Swapping rods, bearings, what ever, is easy. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I understand the internals would be spinning opposite of their designed intent. But just as a mental exercise:
If you install a 911 transmission in a 914 (type 4, etc) you get 5 'reverse' gears. If you then install a Corvair motor and spin that transmission backwards, don't you get 5 'forward' gears? It's still running on the 'backs' of the gears, but wouldn't flipping the diff be counter productive? |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,410 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
I understand the internals would be spinning opposite of their designed intent. But just as a mental exercise: If you install a 911 transmission in a 914 (type 4, etc) you get 5 'reverse' gears. If you then install a Corvair motor and spin that transmission backwards, don't you get 5 'forward' gears? It's still running on the 'backs' of the gears, but wouldn't flipping the diff be counter productive? I shouldn't post because I'm talking out my ass. Pfffphbbrfft. But another mental exercise: In both the 914 and 911, the main gear stack is rotating the same direction. The flipped diff is the diff(erence). So a 911 tranny in a 914 still has the main stack going the correct direction... Just the diff backwards. Spin the whole thing backwards and that makes up for the diff diff, but the core stack is now backwards. So yeah, Corvair motor plus 911 tranny = 5 gears forward and 1 reverse... But after all of this shell game, the core stack is backwards... Which is said to be bad? If two wrongs makes a right, does a wrong plus a wrong plus a right make everything wrong but actually right because it is anti counter productive? (IMG:style_emoticons/default/blink.gif) This will make more sense after I have a beer. |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
I understand the internals would be spinning opposite of their designed intent. But just as a mental exercise: If you install a 911 transmission in a 914 (type 4, etc) you get 5 'reverse' gears. If you then install a Corvair motor and spin that transmission backwards, don't you get 5 'forward' gears? It's still running on the 'backs' of the gears, but wouldn't flipping the diff be counter productive? I shouldn't post because I'm talking out my ass. Pfffphbbrfft. But another mental exercise: In both the 914 and 911, the main gear stack is rotating the same direction. The flipped diff is the diff(erence). So a 911 tranny in a 914 still has the main stack going the correct direction... Just the diff backwards. Spin the whole thing backwards and that makes up for the diff diff, but the core stack is now backwards. So yeah, Corvair motor plus 911 tranny = 5 gears forward and 1 reverse... But after all of this shell game, the core stack is backwards... Which is said to be bad? If two wrongs makes a right, does a wrong plus a wrong plus a right make everything wrong but actually right because it is anti counter productive? (IMG:style_emoticons/default/blink.gif) This will make more sense after I have a beer. stock starter would be a problem! it will still turn "the proper" direction.... |
Lo-Fi Version | Time is now: 26th April 2025 - 02:49 AM |
