Bee Jay's 914-six Conversion, The car just burned down! |
Bee Jay |
Oct 19 2010, 10:21 PM
Member Group: Members Posts: 204 Joined: 22-April 05 From: Lompoc, Ca. Member No.: 3,964 |
I'm baaaack.
Hi everybody. Maybe some of your remember me. I was very active on the 914 forums about ten years ago. I rebuilt my 1.7 fi 73 914 into a Dell Orto carbed, high compression, big cammed, 2.0 liter. Tom Gould, Wayne Dempsey, and I built the motor in Wayne's Manhattan Beach apartment garage. Gill Paszek helped me with the five lug conversion, and numerous other projects like a passenger footwell sub woofer. I also mounted BMW 320i front brakes, thru the body roll bars, and fuchs replicas. I had the engine compartment and body painted Gaurds Red. John Larson of West Coast Garage rebuilt my 901 tranny and helped me keep the car running, cause I drove it like I stole it. Driving the car was a blast for the past ten years. I blew the engine twice, once with a blown head gasket, and another dropped valve seat, (my second). EMS wanted $800 to fix the head this time, so I decided it's time. I've been wanting to do the six conversion for over ten years, so I'm finally going to do it. I actually started a few months ago. I thought I should do a conversion thread. Six conversion threads used to be very plentiful, but I don't see so many anymore. I would appreciate links, cause I'm gonna need a lot of information, advice, and of course, parts. Here is the car now, well I've removed the 2.0 liter motor. Bee Jay (IMG:http://www.914world.com/bbs2/uploads_offsite/i52.photobucket.com-3964-1287548516.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i52.photobucket.com-3964-1287548517.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i52.photobucket.com-3964-1287548517.3.jpg) |
IronHillRestorations |
Feb 13 2011, 10:44 AM
I. I. R. C. Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Cut the hard line and silver solder or braze a AN fitting on it. You can get a steel 3/4" NPT /-12AN fitting, cut off the pipe threads and drill the fitting to accept the steel oil pipe, and braze it on. I've done a few like that.
Another option is to put a metric to AN adapter right on the case (where the oil pipe connects) and go with flex lines from that point. It's easier an less exposure to heat if you put a 90* fitting on the hose end that's going to connect to that fitting on the case, and then route the hose rearward, wrap it around the passenger side of the engine and then back to the tank, or to a t-stat if you are running an aux oil cooler. |
dion9146 |
Feb 22 2011, 10:08 AM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
Another option is to put a metric to AN adapter right on the case (where the oil pipe connects) and go with flex lines from that point. It's easier an less exposure to heat if you put a 90* fitting on the hose end that's going to connect to that fitting on the case, and then route the hose rearward, wrap it around the passenger side of the engine and then back to the tank, or to a t-stat if you are running an aux oil cooler. EXACTLY the route that I took, except I also have a thermostat on the right side of the engine compartment leading to an external cooler. Routing the flex line rearward and over the headers kept it away from the heat between the headers/heads. And here I thought that I was the only one who took that bonehead route.... (IMG:style_emoticons/default/smile.gif) Dion |
Lo-Fi Version | Time is now: 26th June 2024 - 11:52 AM |
