> cooling fan, did I screw up?
surfbus66
post Feb 22 2011, 04:57 PM
Took the pulley off of cooling fan to blast and repaint. Just noticed when blasting that there is a small piece of metal pounded into the pulley. Did the factory do this for balancing? If so, did i screw up by not indexing fan and pulley prior to removal? Thanks for your input.
bam914
post Feb 22 2011, 05:37 PM
Yes. Plus the pulley will no longer be centered to the fan hub.
surfbus66   cooling fan   Feb 22 2011, 04:57 PM
bam914   Yes. Plus the pulley will no longer be centered t...   Feb 22 2011, 05:37 PM
detoxcowboy   :popcorn:   Feb 22 2011, 06:49 PM
Jake Raby   Re-centering will be a real bitch.. Unless you hav...   Feb 22 2011, 06:53 PM
surfbus66   Re-centering will be a real bitch.. Unless you ha...   Feb 22 2011, 06:59 PM
Jake Raby   Both.. If its not centered it can't be balance...   Feb 22 2011, 07:20 PM
surfbus66   thanks for your help.   Feb 23 2011, 05:21 AM
- Lo-Fi Version Time is now: 27th December 2024 - 11:48 PM
