Floor Pans- Rust prevention and Tunnel treatement, advice needed |
highways |
Feb 24 2011, 12:30 PM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
Hi all,
I'm working on my floor pans... I have them wire brushed down to bare metal. They are in overall decent shape though there is some rust around the perimeter where they meet the longitudinals. These corners seem innaccesable to all but a small wire brush (toothbrush size). Question is: 1. Should I apply POR 15 Surface Prep, then POR 15 to get in cracks, then Seam Sealer, then maybe another coat of POR 15 over Seam Sealer? 2. Or, should i just do Seam Sealer first over bare metal, partial rust areas around the perimeter? Then follow with POR 15? Second question... the smaller 'cross tunnel'.. the one where the front seat adjustment bracket mounts, is in poor shape. Rust inside it looks bad... some of the lower edges are gone but it's still largely inaccesable to any tools or painting. I think my options are: A. Drill some holes in top, blow it out, and spray as much paint in there as I can and call it a day. B. Cut it out and weld in replacement. But is this part even available? And still how do you paint the bare metal inside after you've welded a new piece in? Any advice would be appreciated. |
MrHyde |
Feb 24 2011, 03:44 PM
Senior Member Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Restoration Design makes new cross members.. look for #20 on this page.
http://www.restoration-design.com/Merchant...ory_Code=914#17 I wouldnt mind knowing what I could spray down in the tunnel too. I dont have any holes there and I'd like to keep it that way. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 05:19 PM |
