> Windshield install
matteyp
post Feb 23 2011, 09:11 PM
Nothing a little JB Weld can't fix...
Hey guys so I was wondering if I could get some insight on windshield installation. I've read in the lupwalli threads that if u use the black rubber seal you need to paint the edges of the windshield so it doesn't show or something. Is this true? Also do u need to fill in all the clips holes with silicone or something? Do u also still need to use the butyl? Thanks for the info.
Matt
toon1
post Feb 24 2011, 09:04 AM
I also installed my windshield recently.
I used the urathane adhiesive instead of the butyl tape, both work good.
I decided on the urathane because it's a glue and they are using on new vehichles.
It was kind of tricky to use but worked good.
If you are going to go with the urathane, have a pro do it.
The Butyl tape is much easier to use.
ALSO there are two spacer blocks that go under the widshield,between the frame and the windsield that keep the glass from eventually settling/creeping down onto the body/windshield frame.
If you use the black rubber trim like mentioned in the classics thread, you won't need the the blocks or the trim clips
post Feb 24 2011, 05:33 PM
Resident German
QUOTE(toon1 @ Feb 24 2011, 07:04 AM) *
The blocks are used to position your windshield correctly so it doesn't sit too low. You need those regardless of what trim you use ...
My Windshield install:
http://www.914world.com/bbs2/index.php?s=&...st&p=910188
(IMG:http://www.914world.com/bbs2/uploads/post-179-1181552583.jpg)
matteyp   Windshield install   Feb 23 2011, 09:11 PM
ConeDodger   I used the original butyl rubber rope method. You ...   Feb 23 2011, 09:48 PM
gothspeed   I have the same questions as the OP ............ I...   Feb 24 2011, 07:46 AM
mojorisen914   The paint you want to use is the Frit paint. Like ...   Feb 24 2011, 07:51 AM
toon1   I also installed my windshield recently. I use...   Feb 24 2011, 09:04 AM
ConeDodger   I also installed my windshield recently. I us...   Feb 24 2011, 10:48 AM
gothspeed   I also installed my windshield recently. I us...   Feb 24 2011, 11:28 AM
SirAndy   If you use the black rubber trim like mentioned in...   Feb 24 2011, 05:33 PM
Eric_Shea   I installed mine as per the factory manual. It wo...   Feb 24 2011, 12:53 PM
sawtooth   What's the best way to remove the old windshie...   Feb 24 2011, 01:12 PM
Root_Werks   What's the best way to remove the old windshi...   Feb 24 2011, 02:22 PM
mepstein   :D   Feb 24 2011, 01:20 PM
sawtooth   I figured that was coming... <_< but what i...   Feb 24 2011, 01:23 PM
Drums66   :D ...Ya I love the sound of breaking glass :ev...   Feb 24 2011, 05:23 PM
mepstein   There are some threads about removal. They crack e...   Feb 24 2011, 01:31 PM
sawtooth   There are some threads about removal. They crack ...   Feb 24 2011, 01:33 PM
Rex-n-effect   I recently removed mine. I started at the lower ri...   Feb 24 2011, 02:42 PM
matteyp   Ok so if I use the rubber seal do I need to silcon...   Feb 24 2011, 03:53 PM
Joe Owensby   Don't use silicone to fill the holes. It cre...   Feb 24 2011, 04:50 PM
- Lo-Fi Version Time is now: 27th December 2024 - 08:48 AM
