Rimco has moved |
Rimco has moved |
76-914 |
Feb 25 2011, 11:02 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Just spoke with Todd at Rimco and found that they are in the middle of a move. This is why things are taking a little longer, now. They should be in full swing by Monday. (IMG:style_emoticons/default/piratenanner.gif) My case is std; needs no line bore and crank can be polished to std. hot dog (IMG:style_emoticons/default/beerchug.gif)
EDIT: Their new # 562.946.3100 |
Cap'n Krusty |
Feb 25 2011, 03:35 PM
Standard cases and cranks are still pretty common for T4 engines. The big problem is the deck (sometimes called the cylinder spigots). They collapse in the center, making a good seal at both the case end of the cylinders and at the heads nearly impossible.
The Cap'n |
Lo-Fi Version | Time is now: 27th December 2024 - 12:58 PM |
