Welders Chime In Please!, Lincoln weld pak 100 shorts where wire enters gun! |
Jeffs9146 |
Feb 25 2011, 01:35 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Lennies914 is in the field welding on a large CoGeneration system and is having problems with the welder. The system is built into a building and wired into the electrical system. The welder is pluged into the wall and the CoGen unit is shut off.
When the welder ground is attached to the CoGen unit and he attempt to weld the wire heats up inside the feeder and the wire melts and balls up! If he disconnects the ground the wire feeds fine. I used this welder a week ago and it worked great at my house! The question is: What would cause this? Would the fact that the CoGen system is grounded to the same plug that the welder is pluged into cause a problem? If a battery is hooked to the CoGen system would that cause this problem? OR Is there anything else that may cause this problem? |
Jeffs9146 |
Feb 25 2011, 08:43 PM
The welder is sitting on a cart that is on rubber wheels!
Lennie, maybe the cart was touching the motor or something that was grounded to the engine?? |
Lo-Fi Version | Time is now: 27th December 2024 - 01:46 PM |
