Electrical troubleshooting help needed |
pauldunn |
Feb 25 2011, 07:55 PM
dudeface Group: Members Posts: 41 Joined: 9-February 11 From: Arizona Member No.: 12,687 Region Association: Southwest Region |
im hoping someone can help lead me in the right direction with this next problem im trying to conquer. on my "72, as soon as i put the cables on the battery the generator light and the oil light come on, and the top 2 red lights on the gas guage blink. and it sounds like the blinker relay is causing the red lights to blink. the oil sensor and the generator sensor wouldnt cause that to happen if they werent plugged in, so i think. wut should i look for? does anyone have an idea?
underthetire |
Feb 25 2011, 09:36 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Remove the power relay on the relay board. If it still does it, could be a shorted diode in the alternator. If it doesn't, check your ignition switch. I'm sure someone else will chime in with other suggestions as well. Good luck.
Lo-Fi Version | Time is now: 27th December 2024 - 09:42 AM |
