> Rimco has moved
76-914
post Feb 25 2011, 11:02 AM
Just spoke with Todd at Rimco and found that they are in the middle of a move. This is why things are taking a little longer, now. They should be in full swing by Monday. (IMG:style_emoticons/default/piratenanner.gif) My case is std; needs no line bore and crank can be polished to std. hot dog (IMG:style_emoticons/default/beerchug.gif)
EDIT: Their new # 562.946.3100
Cap'n Krusty
post Feb 25 2011, 03:35 PM
Cap'n Krusty
Standard cases and cranks are still pretty common for T4 engines. The big problem is the deck (sometimes called the cylinder spigots). They collapse in the center, making a good seal at both the case end of the cylinders and at the heads nearly impossible.
The Cap'n
post Feb 25 2011, 09:39 PM
QUOTE(Cap'n Krusty @ Feb 25 2011, 01:35 PM) *
The Cap'n
And if it is then it is (IMG:style_emoticons/default/stromberg.gif) ? Or is there an alternative?
- Lo-Fi Version Time is now: 27th December 2024 - 01:11 PM
