> Welders Chime In Please!, Lincoln weld pak 100 shorts where wire enters gun!
Jeffs9146
post Feb 25 2011, 01:35 PM
Ski Bum
Lennies914 is in the field welding on a large CoGeneration system and is having problems with the welder. The system is built into a building and wired into the electrical system. The welder is pluged into the wall and the CoGen unit is shut off.
When the welder ground is attached to the CoGen unit and he attempt to weld the wire heats up inside the feeder and the wire melts and balls up! If he disconnects the ground the wire feeds fine. I used this welder a week ago and it worked great at my house!
The question is:
What would cause this? Would the fact that the CoGen system is grounded to the same plug that the welder is pluged into cause a problem? If a battery is hooked to the CoGen system would that cause this problem? OR Is there anything else that may cause this problem?
Jeffs9146
post Feb 25 2011, 09:57 PM
Ski Bum
Thanks Rick! I think we have eliminated a problem with the welder! Lennie tested it when he got home today and it works fine at his house!
It has to be a ground loop coming from the CoGen unit to the circut breaker ground panel!! Even if the breaker is turned off the ground is a constant and as kg6dxn said the neutral may also be looped in the system through the CoGen 120v generator!
Jeffs9146   Welders Chime In Please!   Feb 25 2011, 01:35 PM
underthetire   Probably ground looping. Lennie has my number   Feb 25 2011, 01:45 PM
Jeffs9146   Thats what I told him it could be! I am just l...   Feb 25 2011, 01:46 PM
stugray   The inside of a wire feeder is isolated from the o...   Feb 25 2011, 03:23 PM
toon1   There are + and - wires inside the flip up door th...   Feb 25 2011, 07:27 PM
Lennies914   There are + and - wires inside the flip up door t...   Feb 25 2011, 08:25 PM
Lennies914   Thanks Guys, I just got home and tried my welder....   Feb 25 2011, 08:10 PM
rick 918-S   Is the welder sitting on the Co Gen unit? There ma...   Feb 25 2011, 08:32 PM
Jeffs9146   The welder is sitting on a cart that is on rubber ...   Feb 25 2011, 08:43 PM
Lennies914   The welder is sitting on a cart that is on rubber...   Feb 25 2011, 08:47 PM
kg6dxn   Are you using a power recepticle from the Co Gen? ...   Feb 25 2011, 08:47 PM
Lennies914   Are you using a power recepticle from the Co Gen?...   Feb 25 2011, 08:51 PM
Jeffs9146   That was my first explanation when Lennie called...   Feb 25 2011, 09:12 PM
rick 918-S   Check the liner. The liner could be contacting a g...   Feb 25 2011, 09:43 PM
Jeffs9146   Thanks Rick! I think we have eliminated a prob...   Feb 25 2011, 09:57 PM
rick 918-S   Thanks Rick! I think we have eliminated a pro...   Feb 25 2011, 10:00 PM
kg6dxn   kg6dxn said the neutral may also be looped in th...   Feb 26 2011, 12:04 AM
Racer Chris   I didn't read all the answers above, but my fi...   Feb 26 2011, 03:12 AM
toon1   There are + and - wires inside the flip up door ...   Feb 26 2011, 10:38 AM
- Lo-Fi Version Time is now: 27th December 2024 - 12:54 PM
