rear brake rant, WTF/ humbling e-mail to PMB |
914 shifter |
Feb 26 2011, 06:16 PM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
hello Eric, i am obviously an amateur, and now i am paying for it. i am having a problem with the hardware from my calipers. the bolts, and pins from my caliper halves do not appear correct for the ones you sent. it is possible the po owner/owners rebuilt the calipers with the wrong bolts, and pins. of course i did not notice this during disassembly. i also did not notice during assembly until to late. there are 2 long and 2 shorter bolts. i am confused i attached some pics. i have now fouled up the threads in the caliper you sent. in my ignorance i attempted to to attach the caliper halves using the shorter, and longer bolts in the shorter and longer threaded bores. at about 10-15 ft lbs. the one bolt, or threaded hole stripped. i turned over the caliper, and to my dismay observed the bolt was not near the end of the threaded bore. is it possible i sent you a pair of oddball calipers that mated to these bolts and pins. everything was going so well up until this last
easy part i am so pissed at myself. if you could i would appreciate your help.i hope you are not running out of patience with me. some of the things done to this car by po are f'n mind boggling. God help me!?, and you to Eric. Hank : 914 World FYI my car is a 1970 the calipers on the car were the later 2 bleeder type. i sent them to PMB, and they sent me another refurbished 2 bleeder set. i would appreciate any help with correct hardware. i hope i can tap the threads in the caliper hole i (IMG:style_emoticons/default/sheeplove.gif) up. humbled Hank Attached thumbnail(s) |
Eric_Shea |
Feb 26 2011, 08:31 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Replied via mail as well.
Bolts and pins are correct. Your pins are actually in the proper spot. Two Long - Middle Holes Two Short - Outside Holes |
Lo-Fi Version | Time is now: 31st October 2024 - 07:29 PM |
