rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
In case anyone has to replace their CHT sensor which is a PITA, you'll have to make some type of tool. I ground down a corner off a 3" extension, and attached a deep socket.
It's much easier to install and uninstall if you remove the decel valve and MPS. Here's a picture of the extension and socket with the CHT ready to install. I attached the washer to the CHT sensor with a drop of superglue: ![]() |
nowlings |
Newbie ![]() Group: Members Posts: 28 Joined: 21-March 07 From: sacramento Member No.: 7,615 ![]() |
In case anyone has to replace their CHT sensor which is a PITA, you'll have to make some type of tool. I ground down a corner off a 3" extension, and attached a deep socket. It's much easier to install and uninstall if you remove the decel valve and MPS. Here's a picture of the extension and socket with the CHT ready to install. I attached the washer to the CHT sensor with a drop of superglue: ![]() That is Slick! It's amazing, I never thought about grinding the corner of the extension. I've alway fenagled it by just using the deep well socket and using the wire with tension to guide the sensor to the hole. you have a cool tool there and now I'm going to make mine. I don't know about you, but I find myself replacing that sensor every couple of years. |
rwilner |
Lo-Fi Version | Time is now: 26th June 2024 - 05:49 AM |
