> new carb issue - i think
william1764
post Mar 5 2011, 10:29 AM
Finally corrected the serious backfire issue i had (IMG:style_emoticons/default/cheer.gif) exhaust leak was found (crack at header mount flange area) and repaired...long story but excessive/loud backfire on decel has been FINALLY eliminated. Overnight however i developed a sputtering/popping thru carbs. Uneven and rough acceleration up thru 3k RPM and higher. idle is irregular but constant - either a little high or a little low but steady...varies on the day. I have noticed since the carbs were rebuilt last september fuel mixture out of the exhaust at startup...i assume too rich? new plugs already dark. i've only put on a couple hundered miles since carb rebuild so not much experiance since rebuild.
what could happen to cause the engine/carbs to take such a drastic turn from one day to the next with touching them? Could this be valve issue?
for those not familar with past issues my set up is 74 2.0 with weber dual IDF 40's.
on another note, anyone in balt/dc going to hershey?
jmill
post Mar 6 2011, 02:20 PM
Green Hornet
QUOTE(william1764 @ Mar 6 2011, 07:43 AM) *
is there an easy way to tell if linkage out of adjustment?
Use the search function on this site and you'll get boat loads of weber tech and tip info. Below is one I found that should help you out.
http://www.carburetorclinic.com/weber_tech.htm
william1764
post Mar 6 2011, 07:14 PM
QUOTE(jmill @ Mar 6 2011, 12:20 PM) *
great link...thanks jim (IMG:style_emoticons/default/bye1.gif)
- Lo-Fi Version Time is now: 27th December 2024 - 08:39 AM
