oil gauge, overheating? |
914itis |
Mar 13 2011, 05:07 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
My oil temp gauge stays at about 70% is that normal? i also have an engine temp on spark plug # 3 it stays at 350...
this is about a 75 miles drive, mostly going uphill, the waeter is 50 degrees Attached image(s) |
Ian Stott |
Mar 13 2011, 06:53 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I think your temperature gauge is reading a bit high, check your engine tin seals and the grommets that go through the engine tin, get that all sealed the way it should be and and check your timing if your temps are still the same on the gauge chime in here again and the engine guru's will have better advice than me.
Ian Stott Moncton Canada |
Lo-Fi Version | Time is now: 26th September 2024 - 05:27 PM |
