Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Does the bushing have to be pressed in and out or can it be done with a hammer. (IMG:style_emoticons/default/smash.gif)
I don't want to screw up the PERFECT shift rod that Eric Shea sent to me! And THANK YOU again Eric. I'll post a picture when I get the bushing in and the rod installed. Man, my car is really going to be fast with that power coated shift rod! (IMG:style_emoticons/default/biggrin.gif) |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Me think you have front and back rods inverted.
At least for late model side shift. aft rod has the coupler. the pin is pretty much held in place with the two plastic bushings and a slight interference fit of the pin in the rod end. the forward rod inside the tunnel is a straight rod and will pull right out the back if you disconnect the shift handle. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:49 AM |
