Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Does the bushing have to be pressed in and out or can it be done with a hammer. (IMG:style_emoticons/default/smash.gif)
I don't want to screw up the PERFECT shift rod that Eric Shea sent to me! And THANK YOU again Eric. I'll post a picture when I get the bushing in and the rod installed. Man, my car is really going to be fast with that power coated shift rod! (IMG:style_emoticons/default/biggrin.gif) |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Joe, Thanks. You are correct. As you stated, the universal joint is pinned to the rear rod, not the front rod. It slips on the front rod and is held by a tapered set screw.
When I wrote my earlier description I took a moment to look at the gearshift linkage illustration in the Haynes manual. I had even replaced the bushings in my universal joint not so long ago. And I still screwed up my instructions! (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:53 AM |
