r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
So,
How useful are the 5-6 foot scissor lifts versus the standard 2 post lifts.? I am about to buy a new one...they are the exact same price. The two poster does add , well, two posts to my shop...good or bad has yet to be determined. What are you views? Rich |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
So, How useful are the 5-6 foot scissor lifts versus the standard 2 post lifts.? I am about to buy a new one...they are the exact same price. The two poster does add , well, two posts to my shop...good or bad has yet to be determined. What are you views? Rich Looking into that myself right now (IMG:style_emoticons/default/smile.gif) The scissors is just a bit portable (1000lbs) and has a ground clearance problem. You need to raise the car a bit to fit over the lift. You can see in most pictures that people installed rails to solve the clearance issue. I intend to have the lift in my normal parking spot so parking on the rails every day or moving the lift to the side might be difficult. On the other side, the scissors are much more stable than 2 poles, especially the "portable 2 poles" like they sell at Costco for $2000. Just imagine how the center of gravity moves forward when you remove the engine. I'm a bit afraid that this miss-ballance may cause the poles and car to tilt forward and maybe fall off. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
On the other side, the scissors are much more stable than 2 poles, especially the "portable 2 poles" like they sell at Costco for $2000. Just imagine how the center of gravity moves forward when you remove the engine. I'm a bit afraid that this miss-ballance may cause the poles and car to tilt forward and maybe fall off. A regular two post (poles) like my US made AMMCO will never "tilt" unless it takes the whole floor with it. I've had a full size chevy P/U on mine so I think it can handle a 914. I agree a portable two post or "made in china" lift will not be as good as a commercial lift. I used to R&D and build much larger scissor lifts and I'd say the HF scissor lift is less stable than a two post, only because it's not anchored to a base frame that is bolted to the floor. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:22 AM |
