steering column, wiggle |
tomh |
Mar 27 2011, 08:23 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
my steering column seems to wiggle a bit,The big nut holding the wheel is tight and the 4 allen bolts holding the saddle are good,what other things should i look for or is a little wiggle ok?
SirAndy |
Mar 28 2011, 01:06 AM
Resident German Group: Admin Posts: 41,961 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You can also get a metal "sleeve" that slides between the shaft and the inner race of the top bearing. You tap it in and it will get rid of the slop.
Had one on mine for years, no slop, no problems ... (IMG:style_emoticons/default/smash.gif) |
tomh |
Mar 28 2011, 07:20 PM
You can also get a metal "sleeve" that slides between the shaft and the inner race of the top bearing. You tap it in and it will get rid of the slop. Had one on mine for years, no slop, no problems ... (IMG:style_emoticons/default/smash.gif) Thanks for all the info.is that "sleeve"your talking about the one on PP that is split? |
Lo-Fi Version | Time is now: 6th January 2025 - 04:20 PM |
