> steering column, wiggle
tomh
post Mar 27 2011, 08:23 PM
my steering column seems to wiggle a bit,The big nut holding the wheel is tight and the 4 allen bolts holding the saddle are good,what other things should i look for or is a little wiggle ok?
detoxcowboy
post Mar 28 2011, 07:48 PM
Region Association: Africa
There is an oem bearing that uses the sleeve. There is also an oem replacement that has a plastic ring "built in sleeve". Trying to put the metal oem sleeve into the plastic ringed oem replacement just fuggers up the bearing.. It is either one or the other, unless your oem plastic ringed replacement is so far gone that the oem metal sleeve actually does assist a little..
Found this out the hard way re-ordering things from AA and getting both styles..
Second note: if you put to much torque on the big nut that holds the wheel on trying to solve the wiggle you will lose your turn signal cancel ability and may harm it permenently. Though in most cases easing off on the torque down will reclaim the turn signal cancel ability.. My experience anyways.. 2 cents for what its worth..
tomh   steering column   Mar 27 2011, 08:23 PM
Sleepin   If it gets to bothering you Tom, you will need to ...   Mar 27 2011, 08:54 PM
tomh   If it gets to bothering you Tom, you will need to...   Mar 27 2011, 09:08 PM
r_towle   bearing and bushing get replaced 1-2 hour job. Ric...   Mar 27 2011, 09:10 PM
Sleepin   bearing and bushing get replaced 1-2 hour job. Ri...   Mar 27 2011, 09:21 PM
Dr Evil   Search on here for my post on disassembly, repair ...   Mar 27 2011, 09:48 PM
euro911   My steering column seems to wiggle a bit, The big ...   Mar 27 2011, 11:04 PM
SirAndy   You can also get a metal "sleeve" that s...   Mar 28 2011, 01:06 AM
tomh   You can also get a metal "sleeve" that ...   Mar 28 2011, 07:20 PM
sfrenck   I tried the "sleeve"... should have save...   Mar 28 2011, 07:30 PM
detoxcowboy   There is an oem bearing that uses the sleeve. Ther...   Mar 28 2011, 07:48 PM
Drums66   There is an oem bearing that uses the sleeve. The...   Mar 29 2011, 05:25 PM
tomh   There is an oem bearing that uses the sleeve. Th...   Mar 29 2011, 06:02 PM
SirAndy   ,just to be sure,the sleeve we are all talking abo...   Mar 29 2011, 08:03 PM
tomh   does the knee pad have to be removed or can you ju...   Mar 28 2011, 08:03 PM
sfrenck   does the knee pad have to be removed or can you j...   Mar 29 2011, 05:27 AM
stewteral   my steering column seems to wiggle a bit,The big ...   Mar 29 2011, 12:29 PM
SirAndy   -There is NO sleeve used in the 914, so the 928 P/...   Mar 29 2011, 12:37 PM
Vacca Rabite   I used the corrugated bushing on my car, and even ...   Mar 29 2011, 08:07 PM
charliew   My 75 914 had the plastic sleeve fall apart and it...   Mar 30 2011, 08:49 PM
kconway   I had the same problem so I bought a new bearing. ...   Mar 31 2011, 07:32 AM
Steve   It's been like 20 years since I fixed mine, bu...   Mar 31 2011, 07:59 AM
- Lo-Fi Version Time is now: 6th January 2025 - 03:54 PM
