steering column, wiggle |
tomh |
Mar 27 2011, 08:23 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
my steering column seems to wiggle a bit,The big nut holding the wheel is tight and the 4 allen bolts holding the saddle are good,what other things should i look for or is a little wiggle ok?
tomh |
Mar 28 2011, 08:03 PM
does the knee pad have to be removed or can you just get at it by removing all the guts in the column?
sfrenck |
Mar 29 2011, 05:27 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
does the knee pad have to be removed or can you just get at it by removing all the guts in the column? Sleeve = remove steering wheel and turn signal assembly Bearing = remove the entire steering column (my knee pad was already off so I don't exactly know if it would be in the way) |
Lo-Fi Version | Time is now: 6th January 2025 - 04:11 PM |
