> steering column, wiggle
tomh
post Mar 27 2011, 08:23 PM
my steering column seems to wiggle a bit,The big nut holding the wheel is tight and the 4 allen bolts holding the saddle are good,what other things should i look for or is a little wiggle ok?
stewteral
post Mar 29 2011, 12:29 PM
Old Member
QUOTE(tomh @ Mar 27 2011, 07:23 PM) *
Hey Tomh,
Due to your complaint, I took BOTH steering columns apart from my (2) '73s.
Here's what I found:
-Upper bearing is a crappy design with a plastic inner liner that fails, causing the slop. I spent a couple hours on-line, including calling a "we can find any bearing" house to find that there is NO substitute for the German made 58080 bearing.
-There is NO sleeve used in the 914, so the 928 P/N piece must be for 928s only.
Replacing the failing plastic liner of the bear with a sleeve of your own could work,
but would require some method of keeping it in place....maybe expoxy glue or welding.
-In one column, the bottom bearing WAS BAD! Since it is a STANDARD 6003 bearing it can be bought anywhere. I bought on-line from www.bearingsdirect.com
and paid $4.75 ea (bought 2) + $5.80 shipping for both. Much cheaper than PP!
-To remove the column:
*1st- unbolt the steering wheel and then the steering shaft (I unbolted at the
rack&pinion end as it was easier to get to.
*2nd- Unbolt the 4 Allen-head bolts holding the column to the dash
*3rd- pull the colum out of the car
*4th- unscrew the 4 small machine screws holding the signal & wiper switch assy.
Then slide the whole dual-arm assy out and put aside.
*5th- Turn the column bottom side up and unbold the single allen-head bolt
opposite the ignition switch side.
*6th- Slide the entire steel column out of the black housing
*7th- Lastly, using circlip pliers you can get access to & remove both bearings.
Enjoy,
Terry
tomh   steering column   Mar 27 2011, 08:23 PM
Sleepin   If it gets to bothering you Tom, you will need to ...   Mar 27 2011, 08:54 PM
tomh   If it gets to bothering you Tom, you will need to...   Mar 27 2011, 09:08 PM
r_towle   bearing and bushing get replaced 1-2 hour job. Ric...   Mar 27 2011, 09:10 PM
Sleepin   bearing and bushing get replaced 1-2 hour job. Ri...   Mar 27 2011, 09:21 PM
Dr Evil   Search on here for my post on disassembly, repair ...   Mar 27 2011, 09:48 PM
euro911   My steering column seems to wiggle a bit, The big ...   Mar 27 2011, 11:04 PM
SirAndy   You can also get a metal "sleeve" that s...   Mar 28 2011, 01:06 AM
tomh   You can also get a metal "sleeve" that ...   Mar 28 2011, 07:20 PM
sfrenck   I tried the "sleeve"... should have save...   Mar 28 2011, 07:30 PM
detoxcowboy   There is an oem bearing that uses the sleeve. Ther...   Mar 28 2011, 07:48 PM
Drums66   There is an oem bearing that uses the sleeve. The...   Mar 29 2011, 05:25 PM
tomh   There is an oem bearing that uses the sleeve. Th...   Mar 29 2011, 06:02 PM
SirAndy   ,just to be sure,the sleeve we are all talking abo...   Mar 29 2011, 08:03 PM
tomh   does the knee pad have to be removed or can you ju...   Mar 28 2011, 08:03 PM
sfrenck   does the knee pad have to be removed or can you j...   Mar 29 2011, 05:27 AM
stewteral   my steering column seems to wiggle a bit,The big ...   Mar 29 2011, 12:29 PM
SirAndy   -There is NO sleeve used in the 914, so the 928 P/...   Mar 29 2011, 12:37 PM
Vacca Rabite   I used the corrugated bushing on my car, and even ...   Mar 29 2011, 08:07 PM
charliew   My 75 914 had the plastic sleeve fall apart and it...   Mar 30 2011, 08:49 PM
kconway   I had the same problem so I bought a new bearing. ...   Mar 31 2011, 07:32 AM
Steve   It's been like 20 years since I fixed mine, bu...   Mar 31 2011, 07:59 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 04:22 PM
