> steering column, wiggle
tomh
post Mar 27 2011, 08:23 PM
my steering column seems to wiggle a bit,The big nut holding the wheel is tight and the 4 allen bolts holding the saddle are good,what other things should i look for or is a little wiggle ok?
charliew
post Mar 30 2011, 08:49 PM
My 75 914 had the plastic sleeve fall apart and it would honk the horn when you hit a bump it was so loose. I took it apart and saw what was wrong and ordered a sleeve and it came in and it was just like the one in my son's super beetle. The little wavy metal split one. It's harder but I think I remember putting it in with the lip under the bearing so it would stay in place but zach's suggestion of using a spacer on top of it seems like a good solution to me, I rember reading his thread. I had mine apart more than once before I got it as tight as I wanted it. I think I had to shim the top bearing in the housing some.
tomh   steering column   Mar 27 2011, 08:23 PM
Sleepin   If it gets to bothering you Tom, you will need to ...   Mar 27 2011, 08:54 PM
tomh   If it gets to bothering you Tom, you will need to...   Mar 27 2011, 09:08 PM
r_towle   bearing and bushing get replaced 1-2 hour job. Ric...   Mar 27 2011, 09:10 PM
Sleepin   bearing and bushing get replaced 1-2 hour job. Ri...   Mar 27 2011, 09:21 PM
Dr Evil   Search on here for my post on disassembly, repair ...   Mar 27 2011, 09:48 PM
euro911   My steering column seems to wiggle a bit, The big ...   Mar 27 2011, 11:04 PM
SirAndy   You can also get a metal "sleeve" that s...   Mar 28 2011, 01:06 AM
tomh   You can also get a metal "sleeve" that ...   Mar 28 2011, 07:20 PM
sfrenck   I tried the "sleeve"... should have save...   Mar 28 2011, 07:30 PM
detoxcowboy   There is an oem bearing that uses the sleeve. Ther...   Mar 28 2011, 07:48 PM
Drums66   There is an oem bearing that uses the sleeve. The...   Mar 29 2011, 05:25 PM
tomh   There is an oem bearing that uses the sleeve. Th...   Mar 29 2011, 06:02 PM
SirAndy   ,just to be sure,the sleeve we are all talking abo...   Mar 29 2011, 08:03 PM
tomh   does the knee pad have to be removed or can you ju...   Mar 28 2011, 08:03 PM
sfrenck   does the knee pad have to be removed or can you j...   Mar 29 2011, 05:27 AM
stewteral   my steering column seems to wiggle a bit,The big ...   Mar 29 2011, 12:29 PM
SirAndy   -There is NO sleeve used in the 914, so the 928 P/...   Mar 29 2011, 12:37 PM
Vacca Rabite   I used the corrugated bushing on my car, and even ...   Mar 29 2011, 08:07 PM
charliew   My 75 914 had the plastic sleeve fall apart and it...   Mar 30 2011, 08:49 PM
kconway   I had the same problem so I bought a new bearing. ...   Mar 31 2011, 07:32 AM
Steve   It's been like 20 years since I fixed mine, bu...   Mar 31 2011, 07:59 AM
- Lo-Fi Version Time is now: 6th January 2025 - 03:52 PM
