Teeners race cars, without sails |
Randal |
Dec 28 2010, 10:57 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Got pictures? |
bcaschera |
Mar 3 2011, 12:28 AM
Member Group: Members Posts: 73 Joined: 1-October 09 From: san jose Member No.: 10,873 Region Association: None |
I dont know if it is worth 50 lbs. but the targa bar from sail to sail is about 20 lbs. alone. (That is all that is left from my trarga bar).
Is this really a worth while mod? aren't you sacrificing quite a bit of rigidity by cutting the sails? |
Randal |
Mar 4 2011, 07:58 AM
I dont know if it is worth 50 lbs. but the targa bar from sail to sail is about 20 lbs. alone. (That is all that is left from my trarga bar). Is this really a worth while mod? aren't you sacrificing quite a bit of rigidity by cutting the sails? Thanks for the information. I've gone off doing this project for two reasons, one of which you outline above, i.e., although 20 lbs is a lot, the negative is that you could get protested for cutting into the tub, per SCCA. That wouldn't be a good thing. |
jjackson |
Apr 2 2011, 04:16 PM
Member Group: Members Posts: 219 Joined: 5-October 10 From: maumelle, arkansas Member No.: 12,246 Region Association: None |
I dont know if it is worth 50 lbs. but the targa bar from sail to sail is about 20 lbs. alone. (That is all that is left from my trarga bar). Is this really a worth while mod? aren't you sacrificing quite a bit of rigidity by cutting the sails? Thanks for the information. I've gone off doing this project for two reasons, one of which you outline above, i.e., although 20 lbs is a lot, the negative is that you could get protested for cutting into the tub, per SCCA. That wouldn't be a good thing. Cage work looks great!! What class are you building it for? The season after I cut away the most metal-we broke/fatigued the rear of our old chasis to the point that the car NEVER handled correctly again.So be careful.In some ways it was a blessing-we kept upgrading suspension components until we found the problem-Several frustrating seasons-we got really smooth driving a flexing chassis.JJackson |
Randal |
Apr 8 2011, 10:34 AM
I dont know if it is worth 50 lbs. but the targa bar from sail to sail is about 20 lbs. alone. (That is all that is left from my trarga bar). Is this really a worth while mod? aren't you sacrificing quite a bit of rigidity by cutting the sails? Thanks for the information. I've gone off doing this project for two reasons, one of which you outline above, i.e., although 20 lbs is a lot, the negative is that you could get protested for cutting into the tub, per SCCA. That wouldn't be a good thing. Cage work looks great!! What class are you building it for? The season after I cut away the most metal-we broke/fatigued the rear of our old chasis to the point that the car NEVER handled correctly again.So be careful.In some ways it was a blessing-we kept upgrading suspension components until we found the problem-Several frustrating seasons-we got really smooth driving a flexing chassis.JJackson I'm probably going to run E Mod, but will be underpowered when going against the monster cars. But it will be fun and we'll see if a good handling car can get within shouting distance. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:48 PM |
