WTB Motor Mount for Side shift conversion., The Solid channel type mounts that are on the ends |
falconfp2001 |
Apr 10 2011, 03:54 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I am missing the solid mounts for my side shift conversion. They go on the ends of the bar and fasten to the frame.
Will pay pal for a reasonable price by Wednesday Thanks Attached image(s) |
914Mike |
Apr 11 2011, 12:36 AM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
I am missing the solid mounts for my side shift conversion. They go on the ends of the bar and fasten to the frame. Will pay pal for a reasonable price by Wednesday Thanks You can make those out of two pieces of angle iron, cut to length and drilled. I made one when I came up short after a long rebuild. The missing one just turned up, so I took the sub out yesterday. I say two pieces of angle iron, that means two per side, doubled up on the bottom to make a channel like the original. If you use 1/8" thick angle, about 1" by 1" works, and is actually stronger than the original. The sides being taller made it harder to put the nut on the bolt, that's the only drawback I noticed. |
Lo-Fi Version | Time is now: 24th September 2024 - 01:04 PM |
