falconfp2001 |
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region ![]() |
OK, I need help. I was driving relatively low speed when I hear what sounds like a gear grinding, it was really quick and then gone, and then I lose power. It accelerates but seems to be firing only on two cylinders.
WHAT JUST HAPPENED? I am so bummed as i just got this car back running with the FI. Any one have a super cheap Engine close that I can get to install this weekend? |
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
Might want to use a timing light to see if you're getting spark in the "bad" cylinders. If you verify that have spark, then your fuel injectors might not be firing.
Lo-Fi Version | Time is now: 21st June 2024 - 12:06 AM |
