Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Welcome to my Audi Turbo 914 build thread! This first post has been highly edited for your(and my) ease of navigation.
` (IMG:http://www.914world.com/bbs2/uploads/post-172-1428991066.jpg) ` The car 1973 Porsche 914 1.7 w/ appearance group package (IMG:http://www.914world.com/bbs2/uploads/post-172-1429499049.jpg) ` The Story: I purchased this car when I was 14years old and had bought 2 other 914s with it for a measly $1100, The other 2 914’s were basket cases and one had been in a roll over. The previous owner put the 2.0 from the roll over car in this car. I parted out the other two cars and DID A V8 CONVERSION on mine after I couldn’t figure out how to adjust the valves (It seemed easier..). I do a 5 lug conversion as well as put some fiberglass flares on the car and many other things before I decide to paint the car. That is the start of this thread. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1295463716.1.jpg) ` Next I decide that I don’t like how the v8 drives and how I could never keep it cool so I decide to embark on a journey with an engine I was already more familiar with. The Audi 1.8T. To start at the 1.8T engine conversion click below. http://www.914world.com/bbs2/index.php?sho...4780&st=309 Details on the car: Engine: Audi AEB 1.8t Engine, Fully rebuilt, balanced rotating assembly and blueprinted, balanced and clearanced Intermediate shaft. Crankshaft: Stock/polished Rods: Scat Forged I beam rods Pistons: Stock Cams: Stock Valves: Stock intake, Stainless nitrite coated Supertech exhaust AEVN-1103 Valve springs: Supertech high rpm valves SPRK-AUDI18 Piston rings: Goetze 08-502900-00 (Factory stock) Head gasket: Elring Stock head gasket Rod bearings: 034 Dry film coated bearings 034-202-1008 Crank bearings: 034 Dry film coated bearings 034-202-1000 Intake Manifold: Stock Throttle Body: Stock AWM Exhaust Manifold: APR Iconel Stage 3 manifold Exhaust: 3" turbo back stainless steel w/ 2 stainless resonators Intercooler: 700hp air to water core. Turbo: Comp Turbo triple ball bearing CTB5356 Injectors: Bosch 550CC injectors ported and flow matched to 1300CC Fuel Pump: Bosch 044 inside 034 Surge tank Fuel rail: Stock fed with AN10 line Water pump: Davies Craig EWP150 w/ LCD controller MAF: PMAS HPX MAF in 3" housing Boost controller: Cortex EBC Transmission: Audi A4 1.8 5 speed code EHV FWD unit 100mm stub axles from boxster transmission eBay sprung type LSD Wiring: Strip all Porsche wiring, Replace with Audi wiring 100% Engine Management: Modified OEM Audi Ecu Power brakes: Not yet ABS integration: Not yet Traction control integration: Not yet Launch control: Not yet Cruise control: Yes Climate control/AC: Yes OBD2 full control: Yes Check engine light: No smile.gif Front trunk and rear trunk: YES! 8psi: 240whp (Canyon and autox setting) 14psi: 280whp (Street) 17PSI: 300whp (Track and Street driving) (Estimated power goal) 30psi(E85): 400whp (Full tilt mode) Suspension: Raised 911 spindals up front with Koni yellows Mueller Roller Needle Bearings front and rear in leu of all bushings Turbo tie rods 22mm Torsion bars Nascar front sway bar Koni yellows rear 911 rear hubs with 100mm studs Ground control coil over kit in rear 225lb springs Brakes: 911 A calipers front Stock 914 rear calipers Vented rotors front and rear Porterfield semi race pads 19mm M/C Proportioning valve replaced with T Wheels: Boxter rear 17 x 8.5 twists up front with 245 40 17 911 turbo 18 x 10 turbo twists in back with 285 35 18 Body: Rich Bontempi HPH Flares Front and Rear, Molded 916 front and rear bumpers (front bumper to be reworked completely) 6" ducktail spoiler with supports Engman long stiffening kit Seam welded rear Camp 914 hood shocks rear Camp 914 Euro front turn signals Bike rack (IMG:style_emoticons/default/biggrin.gif) Interior(In Progress): Fully custom interior (Still in design phase) Harness Bar 5 point Cam lock harnesses Pepboys Corbeau style seats ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Now that the intro is done, here is my checklist of things that I want to get done with it. Register *5-15-11* Fix ignition **5-30-11** Tune (again) ecu ** Converted back to Carbs after ECU died 5-30-11** Clean goo in trunk (pic) Install Dr window crank *5-30-11* Change oil ****Finished 1-29-11**** Change water pump *Received Remanufactured pump from Slits 1-26-11****Finished Install w/ hangups 1-29-11**** Flush coolant Finish targa bar S *Started progress on the bar* Dr front 1/4 *Sand day 1 1-29-11* *Bondo Day 2-1-11**Primer Day 2-19-11* Dr door *Sand day 1 1-29-11**Bondo Day 2-1-11*[/url]*Primer Day 2-19-11* Rocker pannels *5-7-11* Dr rear 1/4 *Sand day 1 1-29-11**Bondo Day 2-1-11*[/url]*Primer Day 2-19-11* Trunk *Removed spoiler, Plugged old spoiler holes, Long board sanded trunk* Rear bumper *Page 8* Pass rear 1/4 *4-17-11* Pass door *4-17-11* Pass front 1/4 *4-17-11* Front bumper *5-5-11* Hood *Primer 5-2-11* *Paint 5-15-11* Top *5-4-11[url=http://www.914world.com/bbs2/index.php?showtopic=114780&st=120#] Primer sealer *5-15-11* Paint *5-15-11* Radiator cutouts in wheel well (And replace hood with stock) ***Completed 1-26-11*** Fix headlights *6-8-11* Fix horn Finish seat install ****Progress 1-19-11**** ***Finished 1-26-11*** Finish carpet *6-8-11* Finish front sway bar Fix Dr Door handle This post has been edited by Andyrew: Jan 15 2022, 09:16 PM |
Andyrew |
Today was spent chasing down light bulbs... Arg... 8' fluorescents are not fun... Found some but they were the wrong style... back they went..
Lots of light in the garage now. Should be plenty of light to spray the car in if I put a spotlight on the side while spraying. Next order of buisness was reinforcing the rear fender. Welded in the piece like last time. Though I would use kitty hair but it sucked balls VS the fiberglass putty stuff, it was just way to thin. In the end It worked out but If I would have gone with the putty stuff I would have had less headache. Afterwards I mixed some of the putty stuff with some fiberglass and reinforced the backside of the fender. Strong as can be now. (IMG:style_emoticons/default/smile.gif) Tomorrow Im going to try to convince the GF to help me do some sanding (IMG:style_emoticons/default/smile.gif) (She did say that she would help me sometime...) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,811 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Today was spent chasing down light bulbs... Arg... 8' fluorescents are not fun... Found some but they were the wrong style... back they went.. Lots of light in the garage now. Should be plenty of light to spray the car in if I put a spotlight on the side while spraying. Next order of buisness was reinforcing the rear fender. Welded in the piece like last time. Though I would use kitty hair but it sucked balls VS the fiberglass putty stuff, it was just way to thin. In the end It worked out but If I would have gone with the putty stuff I would have had less headache. Afterwards I mixed some of the putty stuff with some fiberglass and reinforced the backside of the fender. Strong as can be now. (IMG:style_emoticons/default/smile.gif) Tomorrow Im going to try to convince the GF to help me do some sanding (IMG:style_emoticons/default/smile.gif) (She did say that she would help me sometime...) Use a mask. |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:34 AM |
